V9 Beta - TimeLine audio often muted
Posted: 07 July 2018, 15:52
Hello Support,
While using TimeLine to align some scenes to an MP4 file I I noticed that sometimes, when using the function "play from red marker" the audio from the media appears to muted.
See the third play of the timeline: https://youtu.be/2snbJYlKEL4
If I hit "play from the red marker" again generally the audio comes back and TimeLine works well, other times it doesn't and I have to play the TimeLine from somewhere before the beginning of the mp4.
I'm using SweetLight V9.0.2beta2 (64 bits) on Windows 10.
Here are some details about the media file used in the TimeLine:
Complete name : E:\Musiche film\Lightshows\Escape the Fate - One For The Money.mp4
Format : MPEG-4
Format profile: Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 3.56 MiB
Duration : 3mn 18s
Overall bit rate : 150 Kbps
Writing application : Lavf57.81.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 18s
Bit rate : 49.2 Kbps
Width : 854 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.005
Stream size : 1.16 MiB (33%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 18s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 2.27 MiB (64%)
Default : Yes
Alternate group : 1
Format : MPEG-4
Duration : 3mn 18s
Video
Format : AVC
Codec ID : avc1
Duration : 3mn 18s
Width : 854 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3mn 18s
Default : Yes
Alternate group : 1
