Timeline ends at 0:30:00
Postby andypresovsky » 04 July 2018, 23:27
Hello guys,
I came into a problem which I can not solve at the moment. If you had similar experience, please let me know the solution.
I have been trying to create timeline with scenes, but at 0:29:52 the timeline stops and does not allow me to add new scenes.
Screenshot is attached.
Thank you very much in advance.
Andy
[image]
andypresovsky
Re: Timeline stops at 0:29:52
Postby support » 05 July 2018, 11:38
Looks like the timeline duration is 30mn (which is the default duration).
You can change that duration in the window "Timeline settings".
Postby andypresovsky » 05 July 2018, 16:00
Hi guys,
I found that with timeline saved there is file timeline.ini and there you can change the value
MaxTime = 0:30:00
to desired value.
Then it works.
andypresovsky
Postby andypresovsky » 05 July 2018, 16:04
support wrote:Looks like the timeline duration is 30mn (which is the default duration).
Thank you very much. Now I read your answer.
Your solution is cleaner than to edit the text file. I will use it next time. I do not know why I have not seen the Timeline settings option - probably I was not searching well enough.
Thank you again for your support.
andypresovsky
Postby support » 06 July 2018, 10:12
You are welcome.
Please note that all parameters in the text file are adjustable in the software.
Return to Live - TimeLine
Users browsing this forum: No registered users and 11 guests
