V8 - How to enable fade in/out option ? [fixed]
Postby shazammagic » 12 June 2016, 18:20
I was very excited to see this feature added to the list of updates for v. 8.1.10!
Unfortunately, I'm not seeing how to implement/activate this feature in Live > Timeline. Could you provide some more info? Thanks much!
shazammagic
Re: How to enable fade in/out option for scenes in timeline?
Postby support » 13 June 2016, 10:59
In the popup menu "Properties" of the block.
Re: V8 - How to enable fade in/out option ? [fixed]
Postby shazammagic » 14 June 2016, 22:03
Thanks for the clarification. Looks like it only allows for fade out of the light scene, not the accompanying audio track?
shazammagic
Postby support » 15 June 2016, 09:45
Yes, only the light scene.
Postby JT drumhead » 06 December 2016, 17:09
HI. I am new to ShowXpress running version 8.1.29. I was recently instructed, in order to do crossfades from scene to scene within the timeline, I must use the "buttons" mode and program them in as a Fade in and fade out time per button. THEN, the fade times would translate over to my timeline per scene as long as that button/scene was in the timeline. That does NOT work however. May other programs allow you to do a "Crossfade" from scene to scene and manipilate the crossfade times in the timeline directly. Does this SW have this function somewhere? I am very confused on how to do crossfades in timeline. Please explain in detail as the Properties in the Block area description I did not understand in previous post. Thanks
JT
JT drumhead
Return to Live - TimeLine
