Release all / Exclusion / Solo
Postby rockinmo816 » 13 February 2020, 05:03
Pretty sure this cannot be done but we will try anyway...
I have a LIVE page set up with 4 different boards. Each board is a group of LED par fixtures with a DIMMER scene and the applicable colors for that group of lighting. If I set the dimmer scene to be the "Release all buttons exclusion" and the colors set to the "release all buttons" option, that board works perfectly. But, when I select a color from a different board (different page, different scenes, different groups, etc) all of my colors get deactivated/toggled off. Not just the one inside that page. I was under the assumption the SOLO button option for the board/page kept all parameters in that specific container.
Going to check my versions now to make sure I am on the latest and greatest...
-josh
rockinmo816
Re: Release all / Exclusion / Solo
Postby rockinmo816 » 13 February 2020, 05:10
Just updated and checked with 9.2.10 on Mac OSX and still same issue. Either this is a bug or I am not using the features as they were designed.
If there is a way to do what I want, please let me know.
Thank you
Josh
rockinmo816
Postby support » 14 February 2020, 09:53
Postby rockinmo816 » 17 February 2020, 01:20
Thanks for the quick response, but this isnt the issue. I don't beleive what I want to do will work. Adding a screenshot below.
You can see I have four pages in my LIVE screen. Each one of them I want to be able to work independently of each other. I was hoping that by using the "release all buttons" and "release all buttons exclusion" would stay in the page that I am working with and NOT touch the other pages. Unfortunately those release all button options releases all of the other "release all buttons" in all of the pages.
I want it so that if a color is picked in a particular page then all of the other colors in the page turn off. Just so from a user perspective its acting like a color picker.
-josh
[image]
rockinmo816
Postby SeekLighting » 17 February 2020, 01:38
rockinmo816 wrote:Thanks for the quick response, but this isnt the issue. I don't beleive what I want to do will work. Adding a screenshot below.
-josh
You should be able to accomplish what you're trying to do with the "solo buttons" function. That stays within the page
SeekLighting
Postby rockinmo816 » 18 February 2020, 20:01
-josh
I thought that too, but same behavior. When all pages were set to SOLO BUTTONS option, still when I unselected one color in one page, all colors from all other pages that were selected unselected. Unless I am doing it wrong..... I will triple check.
rockinmo816
Postby muscanto » 02 March 2020, 13:20
Just an idea here-
When I want to program a board with it's own "release" button that does not affect other boards, I create an extra flash button on that same board (assuming its a solo board) and use it to do nothing but release whatever is already selected on the board. When you hit that flash button, it will release whatever else is selected. I think that will work as a usable work-around for what you are trying to accomplish.
muscanto
Postby thorehl » 03 April 2020, 18:43
I too have a work around for when _NOT_ using Solo.
Create a macro button that activates all buttons on the given page. Right-click and make it a flash button. -Poff- everything off.
Note: If you get strange flashing of the lights, create a normal button with the fixtures in question with 0 (zero) as value. Add this button to your page and maybe call it EMPTY.
Activate all other buttons, and importantly, and the EMPTY button as the last one and then Right-click the macro button and select Update Macro.
Thore
Using HW: D1024 & D512
Controller: 2x Akai APC mini
my DIY light mixer
thorehl
Return to Live - Buttons
Users browsing this forum: No registered users and 10 guests
