Automatically enable microphone [fixed]
Postby bedo1976 » 01 February 2020, 17:07
Hi
If I start sweetlight Programm / LIVE view, the Microphone / BPM / Beat is not activated. This has always to be done manually. I also didn't found a setting, to check if microphone is enabled at Programm start.
My use case is that sweet light should be used from DJs as well. If the Programm starts, pc boot then Beat / BPM / Microphone should be enabled. Can you provide such a feature.
Bernhard
bedo1976
Re: Provide a possibility to automatically enable microphone
Postby support » 04 February 2020, 11:54
This is possible by modifying an "ini" file in the lightshow (this is not possible via the UI):
- open the file "../YourLightshow/Live/Live.ini"
- add the line "auto_bpm_on = yes" just below the line "[live]"
[live]
auto_bpm_on = yes
Caution: any typo error in this file may damage completly your pages/buttons setting in screen "Live".
So before doing that, please make a safe backup of your complete lightshow.
Re: Automatically enable microphone [fixed]
Postby bedo1976 » 09 February 2020, 14:29
Thanks, it works fine
If possible set this value in futher Version with Default value auto_bpm_on = yes. It would also be helfpul, if this Setting can be changed via GUI, or if activating this in the GUI this Setting should be stored in the ini file.
bedo1976
Return to Live - Buttons
