V9 Beta - problem with capital letters and Virtual DJ
Posted: 24 July 2018, 18:02
I've noticed, in Virtual DJ, that I can only get a few buttons to press in Showxpress with our light show. I don't know if spaces in the button names is causing the issue or not. I've tried renaming the buttons, replacing spaces with "_" and restarting both software's. Sometimes I can get the button to be press (via VDJ) in Showxpress momentarily then it will not engage again (usually after restarting Showxpress).
I don't know if single quotes or double quotes make a difference for the button configuration name in VDJ. In the V9_news PDF, the instructions show double quotes, but the image uses single quotes. I have tried both, with same results.
Beat detection works flawlessly.
Bonjour is installed.
Here is a link to the light show:
https://drive.google.com/open?id=1J-rzMD-ycP6p6mJrK6PddxYFhvTyFeVT
I can get the Fazer page buttons to work (10%, 15% etc). However the "Birthday" (no spaces in name) button on the Birthday/Limbo page I can't get to work. Most of the other buttons have spaces in the names, of which I can't get to be pressed as they should.
I'm not sure if spaces or special characters are an issue or not in the Page Name or Button Name.
Thank you,
Bob
Thank you,
Bob
