midi sequence all 1's will not work....
Postby rockinmo816 » 06 January 2017, 03:45
I am trying to provision my number 1 fader, on device 1 channel 1 type 1 note 1. I CANNOT get this fader to control anything. If I assign a different fader, note 6 for instance, it works perfectly. My only guess it has something to do in the software. Screenshots attached.
-josh
[image]
[image]
rockinmo816
Re: midi sequence all 1's will not work....
Postby support » 06 January 2017, 08:55
Please:
- send your lightshow (viewtopic.php?f=3&t=168)
- tell us what is your midi device.
- send the file "param.ini" (you will find it in "home_directory/TheLightingController/")
Postby rockinmo816 » 06 January 2017, 17:18
Param.ini file attached.
LightShow folder available here: http://crazybeatzdj.com/lightshow.zip
Using an Akai MPD26
Thank you
Josh
param.ini
(727 Bytes) Downloaded 628 times
rockinmo816
Postby support » 06 January 2017, 18:00
Please confirm your OS is Windows XP (unlike in your forum profile).
And please do this:
- open the "Midi logger" window (in main menu "Preferences => Windows"), move the non working midi fader, and send us a screenshot of the window
- do the same thing with the working midi fader
Postby rockinmo816 » 06 January 2017, 19:00
OS is Mac OSX, 10.11 El Capitan
I checked that and it was the same logging (output) for both faders, minus the difference on the NOTE 1 or 2.
Also I noticed the debug window will crash the software if you slide the fader up quickly and repetitively. I will try and get you a screenshot of output soon.
-josh
rockinmo816
Return to Live - Buttons
Users browsing this forum: No registered users and 52 guests
