How to remove a fixture ? [fixed]
Postby seantosz » 28 September 2018, 00:35
I added three fixtures to my pixel board and now I cannot delete them. How do you remove fixtures from the pixels map?! no right click option on menu item and keyboard shortcut does not work
seantosz
Re: How to remove a fixture ?
Postby support » 28 September 2018, 07:44
You can use the lasso to select them.
Then right click over one of the selected fixtures and select "Cut" in the popup menu.
Re: How to remove a fixture ? [fixed]
Postby seantosz » 28 September 2018, 16:38
Thank you for your reply. This is what I wound up doing but this method also commits the fixture to the clipboard memory which is unnecessary and a potential pitfall during consecutive workflow.
seantosz
Postby support » 28 September 2018, 21:31
Noted.
We add in the ToDo list: "add the option 'Delete' in the menu".
Postby support » 12 October 2018, 09:27
Added in the fix file for version V9.1.4 .
Return to Pixels
