different fixtures not working well together [fixed]
Posted:
01 October 2021, 12:53
by jason5d
Hi
I'm trying to make some generator movement only programs with Chauvet Trio and Chauvet 357z irc movers but the pan/tilt channel doesn't show in channels menu.
Ive tried it with 30ch and 15ch on the Trios - no joy
thx
Re: different fixtures not working well together
Posted:
02 October 2021, 17:35
We checked the profiles and we found an error in the IntimidatorSpot375ZIRC(15ch) model.
The fourth channel is "pan fine" instead of "tilt fine".
Please use the attached updated file.
Posted:
04 October 2021, 20:20
by jason5d
thx,
that works with the trio 30ch version, I've noticed the trio 30ch doc has some errors please check the 1st mode channel
here's the Manual:
https://www.chauvetdj.com/wp-content/up ... M_Rev5.pdfAny chance you can add button in steps menu at the top that can change all fade/step buttons to step
Posted:
05 October 2021, 07:50
Noted.
To do that:
Re: different fixtures not working well together [fixed]
Posted:
05 October 2021, 12:00
by jason5d
I mean all the channels. eg when you click said button all the dmx channels across the step menu would change to step and when I click again they would change back to fade
thx
Posted:
05 October 2021, 13:26
For that, select all channels (ctrl or shift + mouse click) (red check mark) and press the transition button of any of them.
