Noted.
May be not possible for us to work on that before V10 (because very sensible), but noted.
Thank you again for your help to make us understand clearly your needs.
DeeStage wrote:I would be very nice if we can type in a number for the offset of each fixture.
At this time its nearly unpossible to set the pan offset of 8 fixtures to the same value.
moving 8 faders to the same spot is really difficult
support wrote:"Global offset / zoom" is now possible in the tab "Fixtures", with this fix: http://download.thelightingcontroller.c ... _05_23.zip
Please try it and give feedback.
support wrote:Hello Tim.
Thank you for this report.
Happy to see this new feature saved your time.
Regarding the "unclear" text, we think this is because you did not installed the updated "language" files which are into the fix file. Can you plese check that ?
Noted for the numerical adjustment.
Noted also for the crash (and sorry for that).
We will try to reproduce it.
