[Request] Add more fixtures to existing generator file
PostPosted: 14 March 2018, 03:32
by SeekLighting
Hi Support,
At the moment, when you have created a project in generator, if you attempt to select another fixture to add to the file, the software forces you to start from scratch. It would be great if there was a way for you to add a fixture to a scene quickly and simply update it.
For example, let's say I have a generator project with 4 moving heads. I then wanted to add a new fixture to the show and add the 5th fixture into the same generator project. It would be great if this were possible in future releases!
Regards,
Tim H
Re: [Request] Add more fixtures to existing generator file
PostPosted: 14 March 2018, 18:02
Noted but not easy.
Please note that you can save the curves.
It is not so flexible than what you are asking for, but it helps.
PostPosted: 15 March 2018, 01:14
by SeekLighting
Thanks for the reply. I understand it would be tricky, but thanks for listening to the suggestion. It would make a lot of users very happy! :D
PostPosted: 26 March 2018, 18:51
by samwise309
+1 for this :D
