The Generator file is restarted
Postby Pink LD » 26 April 2017, 02:00
First let me reference an original post about it from the V7 Days:
http://thelightingcontroller.com/viewtopic.php?f=72&t=3560&hilit=generator+generator
Now there wasn't a clear answer from that posting, however the problem was solved for the rest of the time I used V7. However I finally imported the last of my shows in V8 and I am seeing this problem again.
If I have a Macro call for a generated scene and then the next Macro call for my next look calls for the same generator scene the lights physically jump to the start of the generator scene instead of just playing the generator look from where it is.
In my larger, less frequently used show I mostly used a Timeline to call a generated look and let it run for the duration of the various Macros I would use until I wanted a different static scene look or another generated look via a Timeline, until I would turn off the generated scene I was running at the end of a series of looks.
I know you are moving on to V9 but I am curious if this is something you can fix, or consider it for an improvement in V9?
Thanks.
Pink LD
Re: Generator Question
Postby Pink LD » 26 April 2017, 02:15
Pink LD
Re: The Generator file is restarted
Postby support » 26 April 2017, 07:23
viewtopic.php?f=70&t=5093
viewtopic.php?f=83&t=5049
viewtopic.php?f=70&t=5078
Noted.
No need to make a fourth topic regarding this.
Return to Editor - Generator
