[request] X/Y Separation
Postby Clgsound » 06 December 2016, 06:28
In generator can we have a way to separate the x and y so I can make a movement with only X or only Y.
Clgsound
Re: (Request) X/Y Separation
Postby support » 06 December 2016, 08:26
No, it is not possible to separate the pan&tilt channels.
Re: [request] X/Y Separation
Postby AV Concepts TT » 24 January 2017, 00:39
Try locking the X or Y then generate the movement
AV Concepts TT
Postby samwise309 » 06 February 2017, 19:53
Are you trying to get a "relative" X or Y movement? i.e. your beams are in some position and you just want them to move X or Y?
samwise309
Postby Clgsound » 09 February 2017, 15:34
samwise309 wrote:Are you trying to get a "relative" X or Y movement? i.e. your beams are in some position and you just want them to move X or Y?
Correct. I know how to achieve this by generating my pan or tilt movement, adding to stand alone, uploading, going into editor, load the stand alone scene file, select lights and disable which ever axis I don't want. Thats a lot of steps to be doing every night. seems like with RGB grouping in generator it wouldn't be hard to have X/Y grouped or ungrouped and would save time.
Clgsound
Return to Editor - Generator
