More possibilities in Generator
Re: More possibilities in Generator
Postby TimH » 21 February 2018, 23:06
Stilli wrote:Create your Generator Scene for one mover, create individual scenes for each other mover using the same Generator Scene. Use a Macro to trigger all scenes at the same time. The use of a Pallette will enable each Scene to be edited quickly if needed.
I'm only a beginner at this but that's the way I would tackle it.
Stilli: Of course you can do that. What we're saying is that you shouldn't need to. Many other lighting controllers can do this far quicker, using the system we are describing. It means that in order to create the same effect, while it would take one click and about 5 seconds on another lighting console (Martin M-PC is a good example), using ShowXpress it takes far longer and is much more involved. We'd like this new feature to simplify the process.
TimH
Postby thorehl » 01 May 2018, 19:23
Here:
samwise309 wrote:If this is similar to what you want, do this: Make a circle curve with 4 points. Then, add four more points that overlap exactly on top of each other. So, points 1&5 will be in the same spot, 2&6 in the same spot, 3&7, 4&8. Then in the fixture order menu, rearrange your 8 movers so that each pair are in the same relative position. Basically, order your 8 movers like so: 1,2,3,4,8,7,6,5. Then, under the fixture order option is a reverse pan/tilt menu. Reverse pan whichever movers are going the wrong direction and you'll have a symmetrical movement with 4 groups doing the same thing, but with opposite pan. Lastly, move your shift all the way over to one side or the other.
Dude! This is really a smart workarround. Thanks!
Thore
Using HW: D512 on Win10
Controller: 2x Akai APC mini
thorehl
Previous
Return to Editor - Generator
