Re-Load Version 8 due to USB Driver issue with Win7
PostPosted: 16 October 2021, 11:30
by BLUENINJA9R
Good afternoon,
I updated to version 9 for my D512 on my Windows 7 computer, however, I have since discovered that the drivers will not work for the D512 interface.
I tried re-loading Version 8 software update but it is still opening up the version 9 dashboard.
Is there a way I can go back to Version 8 or will I have to uninstall Sweetlight and lose my shows and set up?
Or, is the only option to buy a Win 10 computer?
Ian
Re: Re-Load Version 8 due to USB Driver issue with Win7
PostPosted: 17 October 2021, 09:08
V8 and V9 need different USB drivers.
Please read this for more details: https://thelightingcontroller.com/viewt ... f=2&t=5789
Looks like an icon shortcut issue.
Try to open the folder of the software and run the file "TheLightingController.exe".
Your lightshows will never be lost, whatever you do with software installations.
However, if you make modifications in a lightshow with V9, V8 may be not able to read it again.
Windows 8.1 is supposed to be ok for V9 (with its USB drivers), but there may be additional Windows files to install, and Microsoft is not chatty about that. It is clear they prefer that people go for Windows 10.
PostPosted: 17 October 2021, 09:11
by thorehl
v9 works fine on Win7. Using it now actually.
Just point the drivers update manually to this dir:
Code: Select all
C:\Program Files\SweetLight\drivers\EFKusb(64bit)
If installed in default directory. I'm guessing you've got a 64-bit pc system
