V9.3.4 - click below fader and it it goes up [fixed]
create scenes with steps
Postby Pauluzzz » 11 April 2023, 17:33
I am not sure where to post issues with beta versions, so I post it here.
This one is repeatable, simply in the Editor / Steps screen change from grouping / ungrouping and the sliders block, once moved up, they cannot go down any longer and the ones that were not up yet, just go step by step.
Pauluzzz
Re: Issues with 9.3.4 Beta
Postby support » 17 April 2023, 08:23
Could you please post a link of a video showing this problem ?
Postby Pauluzzz » 18 April 2023, 16:41
Here you go https://vimeo.com/818809400. Sliders go up, but won't go down.
By the way, the fix file includes this beta version, which is the reason I came about it. To get to the latest software I did a complete new install, which is almost fine because it reads the scenes, sounds and videos from the files in the User directory, except for the 2D images files, these I had to copy over.
Pauluzzz
Postby livetechproductions » 24 April 2023, 20:01
I've experienced the same issue after installing the fix file (which is the BETA version).
Re-installed using the installers on this website to go back to a working version.
livetechproductions
Re: 9.3.4 BETA - click below fader and it it goes up
Postby support » 25 April 2023, 07:44
We will work on this problem asap.
PS: BETA is only because of "DPI scaling" change.
Postby support » 27 April 2023, 09:49
Fixed, and available in the "fix" file (9.3.5 BETA).
https://thelightingcontroller.com/viewt ... =85&t=3438
Re: 9.3.4 BETA - click below fader and it it goes up [fixed]
Postby mrchacha100 » 27 April 2023, 10:07
Thanks for the update but now when saving in a palette the keyboard does not respond with correct characters after pressing spacebar so you cannot save the correct names (if you want a space in the title)
mrchacha100
Postby support » 27 April 2023, 14:23
Is this related to this thread ?
Postby mrchacha100 » 27 April 2023, 15:13
Well the fix for this problem caused a new problem. Would you like me to copy this to another thread for you?
mrchacha100
Return to Editor - Steps
