request - MIDI faders to faders in Steps
create scenes with steps
Postby pikip72 » 19 August 2021, 20:13
il y a t'il possibilité d'utilisé les fader MIDI d'un APC mini pour contrôlé directement les fader dans Editor Steps ?
pikip72
Re: request - MIDI faders to faders in Steps
Postby support » 19 August 2021, 21:58
Désolé mais ce n'est pas possible.
Les messages midi sont patchables soit directement sur les canaux dmx, soit pour piloter les boutons/faders dans Live.
Postby AlfieMando » 14 February 2022, 13:46
Its a shame because this would make creating scenes so much simpler with a midi controller attached. I wouldn't even mind using a different midi controller from the one used in live.
I create or edit scenes at every venue and it is more fiddly using mouse and keyboard rather than a controller.
AlfieMando
Postby Gilles » 15 February 2022, 14:29
+ 1
Gilles
Postby support » 16 February 2022, 09:14
Pouvez-vous SVP nous expliquer comment faire ça avec potentiomètre midi ?
https://youtu.be/I69nvGUSqcw
Postby AlfieMando » 17 February 2022, 19:39
support wrote:Pouvez-vous SVP nous expliquer comment faire ça avec potentiomètre midi ?
If you could just make the each fader bar selectable / adjustable by UP/DOWN on the keyboard atleast it would be easy enough to use a midi knob or slider to mimic up/down behaviour even via the operating system.
The options in the above video can be selected if you just drag the fader to the corresponding dmx range but the main channels that this is good for speeding up setup is x / y / focus.
AlfieMando
Postby support » 23 March 2022, 11:39
Noted for the next major version.
Postby Urs » 03 November 2022, 17:40
+1
I would also welcome it if the STEP faders / channels could be controlled via midi. Programming with hardware faders is much easier than with the mouse. But it is important that the channels are individually assignable, as with the fixtures. I don't always need all channels of a device on the faders when programming.
When is a new major release planned?
Urs
Urs
Return to Editor - Steps
Users browsing this forum: No registered users and 46 guests
