Request - Pan/Tilt or Dimmer curve between steps
PostPosted: 08 March 2019, 16:07
by Bobnjul
If this exists, I haven't discovered it, but if it doesn't... it sure would be nice to create curved paths for pan/tilt movement between steps for moving fixtures. Since curves are possible in the Generator, it seems it would be possible to do the same in the step editor. Perhaps the ability to insert a handle along the line between steps. In that regard, creating/allowing dimmer curves between steps would also be very useful... especial when trying to match dimming between conventional and LED fixtures.
Just a thought for version 10
Bob
Re: Feature Request - Pan/Tilt or Dimmer curve between steps
PostPosted: 08 March 2019, 19:15
Thank you for telling "version 10" :-)
These curves are oftenly embedded in the dmx fixture itself.
In our today opinion, it is better like this because this is very close to the LED itself, and the same curve applied to 2 different brands products should not give a good result..
But we note this, and we will see.
Re: Request - Pan/Tilt or Dimmer curve between steps
PostPosted: 08 March 2019, 19:42
by Bobnjul
I agree in so much as the dimmer curve", but the option would still be awesome. For the pan/tilt positioning being able to set a curve between 2 static steps would be wonderful... the shortest distance move isn't always the best look, and it's really tedious to get a two stepped move to look smooth because of the timing of the steps.
