Palette Naming Errors after 16 palettes [fixed]
create scenes with steps
Postby TimH » 16 August 2018, 00:25
Hi Support,
I believe I have found a bug. After creating more than 16 palettes, for some reason the names of the palettes do not save correctly.
Upon creating the 17th palette, the name of the palette does not save. When you go to use the palette in regular Steps mode, the Palette is simply called "Palette 17", and the name you applied to Palette 17 becomes applied to palette 16, and the names are all then incorrectly named going backwards to 1.
Hopefully that description makes sense! It's a bit hard to explain, I might upload a video later to demonstrate. I have found the same problem occurs when you are creating palettes higher and higher (my current show has about 30 palettes so far).
Running the latest fix file for V9 beta (9.0.4) on Windows 10
Regards,
Tim H
TimH
Re: Palette Naming Errors after 16 palletes
Postby support » 17 August 2018, 09:11
Can you please post a link to download your lightshow ?
Postby TimH » 17 August 2018, 23:45
Hi Support,
I have just emailed my show to support@thelightingcontroller.com
Let me know how it goes! :D
Regards,
Tim H
TimH
Postby support » 18 August 2018, 15:52
It looks there is a problem with the palettes in your lightshow, but when we make the following test:
- we load the demo_show (which has 4 palettes) (http://download.thelightingcontroller.c ... how_V8.zip)
- we add 14 more palettes (total 18 palettes)
We are able to select all of them, in a normal scene in Steps.
So we are presently not able to reproduce the problem.
If you can reproduce the problem easily, please post a video.
Postby TimH » 20 August 2018, 03:28
Thanks Support, here's a video demonstrating the problem:
https://youtu.be/YJsdCSSA-Eg
Regards,
Tim H
TimH
Postby Niffo » 20 August 2018, 15:14
Fixed for next release/fix file ;)
In the meanwhile, you can validate the text using the return key instead of changing cell with mouse.
Postby support » 27 August 2018, 21:32
Return to Editor - Steps
