Copy/Paste step won't work [fixed]
Posted:
22 May 2017, 16:25
by MK109u
Created my first scene. No problems.
Opened a new scene to start work. I change the duration to 1 second. Then go to copy and paste a bunch of steps, and nothing. Not responding at all.
Reloaded the whole program, everything. It will not cop and paste at all in the steps box.
Any fixes to this bug or issue?
Thanks for everyone's help.
Re: Copy and Paste won't work?
Posted:
23 May 2017, 09:06
It seems to works well here.
Please post a video showing this problem.
Posted:
24 May 2017, 18:14
by Pink LD
I have noticed the same thing in Editor since I started heavily programming in V8. I don't need a video. I select say the RGB of par. Select the Red, hit shift, select Blue so that RGB have checkmarks. I then go to the Red and right click for the sub-menu, and select "Copy Selected Channels".
Then I go to the fixture I wish to copy to, select the RGB, right click on the Red and select "Paste on this step only/Paste all steps", and I get nothing.
Posted:
25 May 2017, 16:51
by MK109u
https://youtu.be/9AHimTmM6uwVideo of this issue...private link. No spam.
As you can see, I'm doing both the right-click and also the Command C and P function.
It worked fine the first time.
Just weird problem to have.
Posted:
25 May 2017, 21:34
The scene has only one step, so it does not work.
If you add a second step, then it will work.
Re: Copy/Paste step won't work [fixed]
Posted:
25 May 2017, 22:08
by MK109u
As you can see in the video...I demonstrated with a 30 step example and a one step example...
The 30 step won't copy n paste nor will the one step...
Thanks.
Is it something deeper...like system or version or something?
Posted:
25 May 2017, 22:25
Same answer.
The scene has only 30 steps, and you try to paste after step 30.
If you add a 31st step, then it will work.
