How to use the palettes
PostPosted: 30 August 2016, 07:42
The palette management is handled in Steps.
To manage the palettes, click in button "Menu" in the toolbar and select the menu "Palettes".
To save an existing step of a scene as a palette, right click over the chosen step in the list of steps, and select the menu option "Save as palette".
To use a palette in Steps, click in the level area (the black square below channel icon and above the channel fader), and select the palette in the menu.
To use a palette in Generator, right click over the point in the curve, and select the palette in the dropdown menu.
To remove a palette in Steps on the channel, right click on the channel and select the menu option "Release palette".
To remove a palette in Generator, right click over the point in the curve and select "Release palette" in the dropdown menu.
Please watch this to know how to program a palette: https://www.youtube.com/watch?v=9IJb4Nv ... rTtPOkOgJS
The current demo show uses palettes.
The following palettes are existing:
- wash_lights_stage
- wash_lights_keyboard
- wash_lights_drum
- wash_lights_guitar
These palettes are positionning the 8 wash moving heads to "keyboard", "drum", "guitar" or whole stage.
In Live, the scenes in page "wash lights position" use these palettes. Three of these scenes are static Steps scenes, and one is a Generator moving scene.
You can make the following test:
- in 3DView, move the guitar player to the right (for instance in front of the speaker)
- in Live, switch on the "3D" button and press the scene button "WC_yellow" (leave all other scene buttons off)
- go in in Steps, press the button "Menu" in the toolbar, and select "Palette", to enter in the "Palette edit" mode
- switch on the "3D" button
- select the step "wash_lights_guitar"
- adjust the position of each of the 8 fixtures to the new position of the guitar player (only in this step)
- press the button "Save" in the toolbar
- press the button "New scene" in the toolbar to exit from "Palette edit" mode
- switch off the "3D" button
- go in Live and check the scenes "WP_guitar" and "WP_all" have been correctly updated with the new position of the guitar player
