V9 Beta - Custom Fixture Profile Not Working
Postby Pink LD » 21 August 2018, 15:29
v9.05beta5 - 180815 - 64Bits
(Please note I am not using the latest Fix File posted, it crashed the software and it wouldn't open. So I rolled back.)
This is a profile I made for the ADJ Pro64 LED (7Ch). The dimmer now activates a NC in 3D when I use it. This works in V8. I use the 4th Channel's colour macro for a NC override. But this fixture is now unusable in V9 3D. See the following pictures:
https://drive.google.com/file/d/1SNBek-P67jQKEPm2bbyTxmu3CzeNlqta/view?usp=drivesdk
https://drive.google.com/file/d/1GlXXfy-paTT_Cco3HKopcHgjhFdxXrFN/view?usp=drivesdk
Pink LD
Re: V9 Beta - Custom Fixture Profile Not Working
Postby marco » 22 August 2018, 03:22
Dit u create the fixture in v8 or in v9, if in v8 try deleting the channel that doesnt work and add it new,
I had a simular problem with a led par profile from v8,
Try editing the profile, delete all channels leave the rgb (create a 3 channel fixture)
Then add the remaining channels new, this worked for me
It seems that not all fixtures of v8 work correct in v9
marco
Postby Pink LD » 23 August 2018, 02:08
Nothing I have tried, nor your solutions worked. I can either make a work-around, or just change my programming to not use the Colour Macro channel call of a value of 42 and instead just bring up the RGB faders and effectively. For some reason, years ago calling the Macro colour made sense but I can work around that reason as well.
Pink LD
Postby support » 23 August 2018, 14:37
3D V8 and 3D V9 show both the same result with this fixture here.
We do not really understand what is the problem.
Can you please give us more details ?
Postby Pink LD » 24 August 2018, 02:50
I finally fixed it, but I did have to tweak the profile to make it work in V9. I was actually going to suggest you delete this but if you would like an explanation I could give you one.
Pink LD
Postby SeekLighting » 24 August 2018, 06:11
If you could explain the problem that would be sweet. I've never experienced this issue, and I use a lot of custom profiles I made in V8, however I'd like to know what went wrong here in case I do encounter this! :)
Postby Pink LD » 30 August 2018, 17:47
It just took a lot of fooling around with the settings to find the right combinations that worked.
Pink LD
Return to Editor - Fixtures
