Conventional "fixtures" (parcan not RGB) [fixed]
Postby dorian » 25 April 2018, 19:52
I was wondering the simple way to create a fixture with a single channel, but with a gel that I could preview in 3D. I'm using conventional lights and LED on the same rig. Thank you and sorry to ask, I could not find the answer on my own
dorian
Re: Conventional "fixtures"
Postby support » 25 April 2018, 21:00
Create a one channel (called "dimmer") fixture, and set the following 3D parameters:
- select "parcan old (not RGB)" in the combobox
- press the button "Beam color" and select the color of the gel in the "color setting" window
Re: Conventional "fixtures" (parcan not RGB) [fixed]
Postby dorian » 26 April 2018, 15:08
wow, that was fast and so efficient, works perfectly now...and thank you very much.
Lets create now :)
dorian
Return to Editor - Fixtures
