Column "Fix" copies into various fixtures [fixed]
Postby MTF Showtechnic » 23 December 2014, 13:44
As you can see in the headline I think I've found another bug.
I've added a 4CH Dimmerpack to the fixtures.
Edit the column "Fix" at all 4 Channels to "Strict Values" and stored it - nothing else not even the necessary 2 Steps for each Channel.
And surprise, surprise these 4 "Fix" crosses are copied into another 12 Channel Dimmer, to a Briteq Power Pixel, to a Led Bar....
Then I erased the "Fix" crosses at the 12Ch Dimmer, Power Pixel et cetera.
Double click on the new 4CH Dimmerpack - closed the window without any change and without storing it - and here we go - all the upper listed fixture have the crosses again.
After that I looked a little bit more intensive to the problem:
The copy seems to be always into the first and the last addressed fixture.
To be sure that it's not a problem of my 4CH Dimmer I've added a Dimmerpack from the library (Contest - DIM4x5A)
But still the same behaviour.
Software Version 7.1.29
greetings
Roland
MTF Showtechnic
Re: Column "Fix" copies into various fixtures
Postby support » 23 December 2014, 20:20
Noted.
We will check asap (it might take some days).
Postby support » 05 January 2015, 15:07
Problem found.
Will be fixed asap.
Postby support » 05 January 2015, 16:30
Return to Editor - Fixtures
