Problem with Live Mobile and IOS 5.1?
PostPosted: 09 April 2012, 22:34
by DHoude
I have used Live Mobile quite a bit in the past. But after my iPad updated to IOS 5.1, I can start the app but when I hit Connect it just force closes the program. I have checked IP, Port and passwords on both sides. I have also disabled my Win 7 firewall. Still no luck..
I have a second lighting computer with XP that this also worked with and it does the same thing when I hit connect. Last, I have a Driod (HTC Rezound) with live mobile and that connects to both PCs just fine. So I am pretty sure it is an issue with the IOS version of Live Mobile.
I am running the latest ShowExpress 6.30 Beta 4 (on both laptops) as well. I have gotten the IOS Live Mobile to connect only 2 times out of 30 or so. It just force closes every other time. So there is deffinately something wrong.
Also, I have uninstalled and re installed Live Mobile on the iPad with no luck. Ideas?
Re: Problem with Live Mobile and IOS 5.1?
PostPosted: 10 April 2012, 09:46
Please send your lightshow.
We will check that.
PostPosted: 11 April 2012, 15:59
by DHoude
Just sent it. The droid app works fine though. It just force closes on the iPad only, after I hit connect on the iPad Live Mobile app.
PostPosted: 27 April 2012, 15:58
by DHoude
Any news on this issue?
PostPosted: 27 April 2012, 18:14
Yes.
It looks like, unlike Android, ios has a memory limit for tabs and buttons for each app.
We are trying to define more clearly this limit, but it is not easy since it depends of all gadgets (tabs, buttons, ...) the app use.
PostPosted: 28 April 2012, 15:48
by DHoude
So if I take some tabs out, it may work?
PostPosted: 28 April 2012, 18:32
Yes, it should work with less tabs.
