Shehds - 275w 10R Moving Head Light
Re: Shehds - 275w 10R Moving Head Light
Postby support » 19 February 2023, 21:35
There is no converter.
Sorry for that.
Postby MJF9579 » 16 April 2023, 15:27
Anyyone know why these lights don't seem to save DMX mode settings? Not sure what I am doing wrong. I set the address and mode to dmx. It works but then if I turn it off and on again, the light never turns on again. The light moves and goes through the programmed movements but doesn't light up again. I have to change the program mode to something else, then back to DMX. Any suggestions?
Also what are the different DMX modes ?
MJF9579
Postby SeekLighting » 17 April 2023, 23:31
MJF9579 wrote: It works but then if I turn it off and on again, the light never turns on again. The light moves and goes through the programmed movements but doesn't light up again.
Judging by your description, this fixture uses a traditional discharge lamp that must be "lamped on". Ie, the bulb inside needs to be turned on separately, via a DMX command. There's usually a particular level on the "control" of "function" channel that will do this. Have you been lamping on your fixture?
Postby Gilles » 18 April 2023, 12:10
Channel = control
no_function,0,99,notusedinlc lamp_off,100,105 no_function,106,199,notusedinlc lamp_on,200,205 no_function,206,251,notusedinlc reset,252,255
Gilles
Postby cyberbuddha » 29 May 2023, 17:08
Hi, I'd just like to ask if anyone here knows why the default position of PAN on startup is facing the right side (the handle side) instead of facing the side of the screen. Is there any way to configure this such that the head faces the screen on power on? Thank you.
cyberbuddha
Postby SeekLighting » 30 May 2023, 02:50
cyberbuddha wrote:Hi, I'd just like to ask if anyone here knows why the default position of PAN on startup is facing the right side (the handle side) instead of facing the side of the screen. Is there any way to configure this such that the head faces the screen on power on? Thank you.
Yes. Use the fixture's onboard menu to invert the tilt
Previous
