ADJ - Tribar Spot
ADJ - Tribar Spot
Postby apfoll » 19 November 2014, 22:17
Is there a profile for this light? Here's a link to their pdf manual. http://www.adj.com/tribar-spot
Thanks.
apfoll
Re: ADJ - Tribar Spot
Postby support » 20 November 2014, 11:12
Done.
Postby apfoll » 20 November 2014, 17:02
Thx. Even though the name on the light is TriBar there are 6 lights on the fixture. Makes no sense but that's the way it is. Your personality file has 3.
I created a file (the 20 channel version) that lets me control the lights just fine. I was hoping to get something for the 3D view that showed a bar with six spots hanging on it. Is that possible?
apfoll
Postby support » 20 November 2014, 22:30
3DView is able to show only one beam per fixture.
To see all 6 beams, you have to create a RGB (3 channels) fixture, and declare 6 of it.
You can create a 5 channels (with shutter and dimmer) fixture for the last one, but the two last channels will not influence the 5 first RGB fixtures.
Postby apfoll » 21 November 2014, 01:01
OK.
apfoll
Postby OJA » 24 January 2015, 06:03
I'm looking for a profile for the same fixture....we are using the Chauvet ShowXpress software on a PC.
OJA
Postby support » 24 January 2015, 08:36
It is available in current software version.
You can also find it here:
for Editor - http://download.thelightingcontroller.c ... on_7.1.21/
for Pixels - http://download.thelightingcontroller.c ... on_7.1.21/
Users browsing this forum: No registered users and 71 guests
