ADJ - Sweeper Beam Quad LED
Postby RGBlite » 08 September 2013, 15:27
http://www.americandj.com/pdffiles/swee ... ad_led.pdf
I would like to use the 39 channel mode. Is that too much to ask?
Whoops! Maybe so! I attempted to make my own profile, but it doesn't save more than 15 channels. Is that the limit for one fixture?
Do you use PIXELS for this type of 8 LED bar fixture? (I haven't explored PIXELS.)
Also, how would you create a 3D fixture like this. There doesn't seem to even be a 3D fixture for color bars, like the ADJ Mega Pixel, and this is a moving (tilting) bar fixture.
Are these kinds of fixtures just not represented in 3D?
Sorry for any ShowXpress beginner questions, as that's what I am. Thanks!
RGBlite
Re: ADJ - Sweeper Beam Quad LED
Postby support » 10 September 2013, 08:52
This fixture is quite complex. Here is the best way to use it, in our opinion.
Déclare the TXT fixture in Setup, and déclare the PXL fixture in Pixels, both at same dmx address.
Then you can make tilt/dimmer/shutter scenes in Editor, and you can make pixel mapping with the 8 rgbw leds in Pixels.
In Live, make one "solo button" page for the Editor scenes, and another "solo button" page for the Pixels scenes.
In Pixels, set the 3 first channels to state "disable", in order to not override the scenes made in Editor.
You will not see the leds in 3DView, but you wll see them in Pixels.
You will not see tilt.
ADJ_SweeperBeamQuadLed(35ch).pxl
(281 Bytes) Downloaded 624 times
ADJ_SweeperBeamQuadLed(ch1to3of35).txt
(403 Bytes) Downloaded 636 times
Postby RGBlite » 10 September 2013, 16:32
Many thanks!
RGBlite
Users browsing this forum: No registered users and 75 guests
