Need help for dip switch settings for acme dynamo [moved]
post here other topics
Postby vinnymac » 22 May 2011, 10:58
hi i am new to this and am trying to set my 4 acme dynamo scaners up to work with the usb cable sweetlight 100, can somebody tell me what dip switch settings the scaners are supposed to be set to many thanks
vinnymac
Re: Need help for dip switch settings for acme dynamo [moved]
Postby event lighting » 23 May 2011, 13:53
Hi Vinnymac,
The manual for your lights can be found at:
http://prolight.co.uk/images/media/DYNA ... 6b44efdc1b
These scanners use 4 channels of dmx so to be able to operate them all on a seperate address you will need to set the 1st one to 1, the 2nd unit to 5, 3rd unit to 9, 4th unit to 13.
Dip switch settings are:
1 = Dip 1 on
5 = Dip 1+3 on
9 = Dip 1+4 on
13 = Dip 1+3+4 on
Regards
Jon
Event Lighting
event lighting
Postby vinnymac » 24 May 2011, 12:29
Thanks Jon, I will try that tonight is it easy enough to use the sweetlight 100 software making diffrent sences etc
vinnymac
Return to Other
Users browsing this forum: No registered users and 30 guests
