Version 8.2.18 is ready
please read this before posting
Postby support » 14 March 2017, 15:23
The software is available here: viewtopic.php?f=85&t=114
All changes are listed here: viewtopic.php?f=75&t=4344
Caution (if your current version is lower than V8.2.15)
in "Live => Button => Speed properties" all links to the first Speed Master Fader will be lost. You have to manually redo the link for each button where the first Speed Master Fader is used. You have to make this change in your lightshow only one time. Afterwards your lightshow will be ok for all further software versions.
Usb drivers (for Windows only)
Please note that the usb drivers are not anymore automatically installed.
During the software installation process, there is a requester window asking you if you wish to install the usb drivers, or not.
If the drivers are already installed in your system, answer "No" (no need to re-install them when they are already working).
If your Operating system is not up to date, answer "No" (viewtopic.php?f=15&t=4256).
Version 9
For a few weeks, we forked the source code to work on the next major software version "V9".
This means each new feature we add on V8, we have to double the job for V9.
So we will work as less as possible on V8, in order to save our time for V9.
We will of course fix all possible new bugs in V8.
As usually, we can not tell more about V9.
V9 is a long job (months of job), so please do not ask when it will be ready.
Return to Announcement
cron
