Choppy Fades?
Posted:
12 February 2017, 01:16
by shazammagic
When I have a scene which fades my dimmer pack up or down, it appears choppy (i.e., the fade isn't smooth, but appears staggered in obvious steps). Any idea if this is a hardware or software issue?
Running the latest version of the software, on a laptop (Intel Atom 1.66GHz cpu with 2GB DDR3 memory), connected to Box interface, which is connected to a standard four-channel dimmer pack.
Thanks for your help!
Re: Choppy Fades?
Posted:
12 February 2017, 02:38
by BartKrap
Yeah, I've seen something like this on the club's lights as well.
It's only visible in ceratain scenes and/or steps but very noticable.
Re: Choppy Fades?
Posted:
13 February 2017, 11:35
Might come from the interface Box (it is a bit old now).
Should be better with a more recent interface (like D512 for instance).
Re: Choppy Fades?
Posted:
14 February 2017, 08:07
by BartKrap
support wrote:Might come from the interface Box (it is a bit old now).
Nope, we have a D512 and it gives the same problem.
Re: Choppy Fades?
Posted:
14 February 2017, 11:23
Should be better with D512, anyway.
Re: Choppy Fades?
Posted:
14 February 2017, 20:58
by shazammagic
Thanks Support! I did some testing with my Cable interface, and that worked like a charm. I assume the newer interfaces would behave similarly, and I guess my Box unit is showing it's age.
(Sorry you're still having the problem, BartKrap. Is your system completely wired, or do you have any wireless elements in place? I definitely notice a similar choppiness when I'm running the DMX signal wirelessly, but that's the trade-off for not having to run cables.)
Re: Choppy Fades?
Posted:
18 February 2017, 14:04
by BartKrap
shazammagic wrote:Thanks Support! I did some testing with my Cable interface, and that worked like a charm. I assume the newer interfaces would behave similarly, and I guess my Box unit is showing it's age.
Everything is wired, and it's not a problem since I'm the only one who seems to notice this in the club enviroment.
As long as the guests don't mind, I'm fine.
