Page 2 of 2
Re: D512 unit not outputting to lights (windows 10, showXpre
PostPosted: 15 March 2016, 07:03
by JohnRichards
If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
1 - Driver not the correct driver
2 - Incompatible usb 3 port.
I would suggest you try and install on an old machine with Win XP
John
PostPosted: 21 March 2016, 22:03
by ray-j-17
support wrote:And what about #5 ?
Yes, I have done that... sorry for my delayed reply... :3
PostPosted: 21 March 2016, 22:05
by ray-j-17
JohnRichards wrote:If I look at all these faults and it is not a cable fault or box fault it can only be 2 other possibilities.
John
I have tried it on an old windows so machine, it still didn't work. Ill see if I can find an so computer somewhere if needs be.
PostPosted: 14 July 2016, 18:07
by niesten
Here exactly the same :-(
Sweetlight 512 box, always worked fine. A few weeks ago updated to windows 10 and the laptop doesn't recognize the box (0 universes found) and the box shows the standalone led.
DMX bargraphs are showing signal, only 1 light connected (2 diff dmx cables checked, 3 different usb cables, still nothing). Light works with another DMX controller so light is working...
Looks like there is some driver issue for the sweetlight box in windows 10 :-(
Anyone who has Sweetlight box working on windows 10 ?!?
PostPosted: 04 August 2016, 21:21
by BartKrap
niesten wrote:Here exactly the same :-(
Working just fine over here (V8.1.10)
PostPosted: 19 January 2017, 22:45
by ray-j-17
I know it is a long time since I posted this, but I figured I best explain how I sorted the issue (which I did a long time ago. maybe in a galaxy far away, I cannot remember).
this unit does definitely need a USB hub to work. I actually ended up going through 3 or 4 before I was happy with one (and later found out that one of the ones I bought is synonymous with killing apple macs). after I had a good one running, my unit has been working absolutely fine. shame that there were no notes of it needing one anywhere where I bought it. :3
PostPosted: 19 January 2017, 23:11
Thank you for the feedback.
PostPosted: 20 January 2017, 01:37
by ray-j-17
No probs... All I can say is sorry for the delay. Must be a good year by now. :-P
