[6.01] fader 2 drives dmx output 1, and so on [fixed]
PostPosted: 22 April 2010, 12:36
by fotogeci
Driver and software instaled well but when i whant to use fixtures then i cannot controll it because all channels are messed up. That only happens when i use cable dmx usb controller. With box512 is all ok. The cable dmx works only with showexpress 5 software.
Re: Sweetlight software 6 not working with cable dmx controller
PostPosted: 23 April 2010, 08:01
There is a chance that you have this problem: http://forum.thelightingcontroller.com/viewtopic.php?f=11&t=71&start=10&sid=3f83e1ff12b401899f46885881fc9129. In that case, please download and install the fix file.
PostPosted: 24 April 2010, 13:05
by fotogeci
I have installed the fix and now it works just fine. Thanks for support.
