Hello:
I am using ShowXpress with an Xpress 512 Controller.
I am running OSX (Lion) on a new generation Macbook Pro (Intel Based).
I have created a new profile for the OmniSistem LED Curtain (OmniNite OS-9032).
I can access each of the channels for the device and it works as designed (as per the device profile).
However, about every 7 or 8 seconds, the device "flashes" as if it is resetting.
When set for "all on", the lights should remain lit. However, the curtain appears to "flash".
I have read the other notes and am concerned that this has something to do with the DMX refresh rate?
Note: The curtain operates correctly when connected to a Chauvet Obey 40 DMX Controller.
I loaded ShowExpress on a windows PC and experienced the same problem. I checked the firmware version. It is currently 106.
This leads me to believe that the problem is with the software or the controller itself.
Do you have any suggestions?
Thank you,
Tony
