Colordash Accent fixture: no response in visualizer [fixed]
Postby RoyalJenner » 10 April 2011, 17:04
Hello
I added two chauvet colordash accent fixtures, used the available chauvet profile.
The fixtures physically appear in my 3D viewer, but they don't respond to commands. The real lights do.
Please advise how I get the 3D viewer to show the action of the light. Thank you
RoyalJenner
Re: Colordash Accent fixture: no response in visualizer
Postby Allan » 11 April 2011, 19:02
Which COLORdash Accent are you using?
1) COLORdash Accent RGBW
2) COLORdash Accent VW
3) COLORdash Accent UV
Also, if you are using the RGBW, which mode are you using it in?
Modes:
1) ARC 1
2) ARC 2
3) STAGE 1
Allan Reiss
Senior Product Manager
CHAUVET DJ
Allan
Postby RoyalJenner » 11 April 2011, 23:21
stage 1
RoyalJenner
Postby Allan » 12 April 2011, 14:34
I checked the profile here and confirm your problem. There is an easy solution. Please follow these steps:
1) Open SETUP
2) Import COLORdash Accent profile
3) Change channel 7 from "shutter_dimmer" to "shutter"
4) Save the profile
It will now work in 3D view. (Please also check out the attached picture for more details.)
If you have problems, please contact our customer service department and we will email you the revised profile.
Allan Reiss
CHAUVET DJ
Allan
Postby RoyalJenner » 13 April 2011, 02:02
It worked! Thank you :D
RoyalJenner
Postby Allan » 13 April 2011, 13:04
My pleasure! Glad we could solve that problem quickly and easily.
Allan Reiss
CHAUVET DJ
Allan
Return to 3DView
Users browsing this forum: No registered users and 27 guests
