Channel 512 of the highest universe is not managed [fixed]
Postby Pink LD » 05 March 2019, 13:52
Support,
I am using SX V9.1.13 on a Win 10 Pro PC with all the latest updates.
SO I was working with just 3 of the 5 universes I use for my show, i.e. I used the Preferences to have only 3 DMX universes. And I noticed that a Leko fixture I had in U3 on ch512 was not showing in 3D. I checked the DMX Bar Graph and it showed U# ch512 putting out signal. So out of curiosity I swapped several different Lekos and Pars into U3 ch512, same result no 3D presentation, but the DMX Bar Graph shows I am sending signal out from U3 ch512.
I decided to try out another approach and went to a 4 Universe Preference setting, restarted SX, and U3 ch512 was now presenting a beam in 3D. So I swapped the Leko to U4 ch512, saved it, and tried using the fixture, and no beam was presented in 3D.
So I moved the fixture to U2, ch512 and changed the Preferences to 2 Universes, and restarted SX. Same problem.
It would seem that any fixture in Ch512 of the highest universe you are using in SX will not present in 3D.
For now I am just not putting any fixtures into ch512 on the highest universe I have open.
Re: Fixture Features Wont Display in 3D
Postby support » 13 March 2019, 22:01
Yes you are right.
Added in our ToDo list.
Re: Channel 512 of the highest universe is not managed [fixe
Postby support » 21 March 2019, 18:19
Fixed in the fix file (with 3DView V5.1.2).
Return to 3DView
Users browsing this forum: No registered users and 8 guests
