Double Headed Fixtures
Postby Pink LD » 22 August 2018, 02:11
I have 6 double headed LED wash fixtures that have infinite tilt and up to 540 Pan. I programmed them mostly in the office and onsite at gigs but is it likely that 3D could support this type of fixture?
Pink LD
Re: Double Headed Fixtures
Postby support » 22 August 2018, 10:39
Multi-heads are supported, but not the infinite pan/tilt.
Postby Pink LD » 22 August 2018, 18:33
Not Multi head but a fixture with 2 emitters on the same head, so if I pointed the "front" beam to the sky, the "back" beam would be pointed at the floor.
Pink LD
Postby support » 22 August 2018, 20:59
Understood.
Sorry but 3DView V9 is not able to manage such fixture.
Postby Pink LD » 23 August 2018, 02:02
I made the 2nd RGBW as a 2nd head, then in 3D I put them right on top of my other fixtures. Now depending on their orientation I can mimic X but not Y, or Y but not X. Still I can now at least see in 3D when the 2nd side of the head is on. If I could reverse the Pan or Tilt on the 2nd head I could fully simulate my fixtures.
Pink LD
Postby Cablecr69 » 23 August 2018, 11:43
I Have the same issue with a beam on one side and a wash on the other....i too put them togther but certain positions don't work but being able to reverse pan/tilt on individual heads would work.
Cablecr69
Return to 3DView
