importing 3d objects
Postby lindz7228 » 09 November 2010, 01:35
I can't seem to find an answer to my question in sweetlight users' manual. Although Sweetlight webpage says it is easy to import custom 3d objects, I can't find explicit directions how to do this. Can someone help me. I created a 3d set design in .obj format, but don't know how to import it. Thanks.
lindz7228
Re: importing 3d objects
Postby pogjack » 09 November 2010, 03:59
a quick answer while you wait for support's answer. i believe you will open up showexpress (or sweetlight)/ 3dview/ other/ and choose the folder you want it in and save it in that folder. when you open up 3d you should see that option then. good luck
pogjack
Postby support » 09 November 2010, 07:58
Yes, this is correct.
- open the folder of the software application
- open the folder 3DView/other/
- create your own folder (for instance "my3Dobjects")
- copy your OBJ files into the folder "my3Dobjects"
- restart 3DView, and in menu "Object settings -> Bank of objects" you should see your new folder with the new 3D objects
Caution: the 3D objects must be not too complex. For info, the sizes of our 3D objects are less than 100Kb.
Postby pogjack » 10 November 2010, 03:31
what kind of program did you use to make the objects, it there a free version to use to make some simple shapes.
pogjack
Postby lindz7228 » 10 November 2010, 03:49
A reply to pogjack's question: I created the object in the free application, google sketch-up. However, sketch-up doesn't save as .obj file. I imported my sketch-up file into Adobe Photoshop (not free) then converted it to .obj.
lindz7228
Postby Niffo » 11 November 2010, 23:13
Many free programs can generate "obj" files (or Sketch Up Pro). For example, you can use the excellent "Anim8or". "Art of Illusion" is another one written in Java and then multi-platform.
Postby tomrbland » 12 November 2010, 00:44
+1 for Art Of Illusion. It is a very nice program.
tomrbland
Return to 3DView
