One gobo only showing on 3DView [fixed]
Postby djturtlegl » 29 September 2010, 03:00
Hello, I don't know if I´m doing something wrong. When I'm configuring 6 Intimidator spot250 only 1 gobo is showing on the 3DView. I can configure a gobo in the 6 fixtures, but the only way I can see the gobos is in one spot250 each time.
Regards
djturtlegl
Re: One Gobo only showing on 3DView
Postby support » 29 September 2010, 09:38
1 - check you are using software version 6.24 (there was a similar problem in an older version)
2 - if you are using version 6.24 and this problem still happen, you can send us your lightshow. We will check it.
Postby djturtlegl » 01 October 2010, 03:08
Thanks for the help. I´m using the 6.24 beta 1 version. Attached is my ligthshow
Regards
djturtlegl
Postby Niffo » 01 October 2010, 11:41
Please unselect the "Show backside" checkbox in the "3D settings" and all your gobos will be visible.
We will correct this problem for the coming versions, but there is no need to use the "Show backside" option when using supplied 3D objects.
Postby djturtlegl » 02 October 2010, 21:17
Now is working, thanks
djturtlegl
Return to 3DView
