by Allan » 27 March 2014, 21:20
You can get the master dimmer to work by assigning that channel to the master fader. Right-click the fader and select EDIT. Then check the box that cooresponds to the dimmer.
The zoom cannot be controlled by the master fader, but it can be set to respond to an external MIDI command (knob, fader) if you want to take it that far.
Allan Reiss
Senior Product Manager
CHAUVET DJ
