generator > generate > fail playback?
create lighting scenes
Postby MickeyMick » 27 June 2013, 20:59
I got a problem.
Im programming my heads in the generaot. Playback goes well.
When i generate the selected, it fails in normal playback.
How is that?
house hardstyle.rar
here is the gen file, generate it and see what happens :(
(694 Bytes) Downloaded 1060 times
MickeyMick
Re: generator > generate > fail playback?
Postby support » 28 June 2013, 06:51
In order to have a chance to help you, we need to understand the problem.
Please give us more details.
Postby MickeyMick » 28 June 2013, 09:11
Step 1. I open the gen.
step 2. i open the file ive been sending u
step 3. ill play the file in the gen to see what it does :)
step 4. generate it to a scene.
step 5. playback in normal mode (not the generator)
step 6. it fails to playback my scene. Only 1 head moves and it doesnt look like my scene in the generator ;)
See my gen file to see what i have done.
short summary:
Heads move in a circle, and the lights go on and off with the dimmer.
i made a pattern like this: UUUUU but upside down. so the go on off on off on off very fast ;)
It works in the gen so why wouldnt it work in normal playback?
MickeyMick
Postby MickeyMick » 28 June 2013, 09:24
o and please hurry. I need the scenes tomorrow :O
Only 1 light works in playback mode (normal mode) but in the gen both work. So no problems with the light.
MickeyMick
Postby support » 28 June 2013, 13:50
You posted only one file.
We need the complete lightshow.
Please post the complete lightshow.
Postby ERC » 19 December 2013, 15:43
Any news on this because I had the same problem yesterday!
No need to upload shows just test it with 6 moving heads patched in Editor, open generator, make a circle and push Play, now you see it runs fine in a good loop. Now generate this circle to Editor and play it from there and you'll see .... Problem.... no seamless loop anymore....
Help is wanted :?
ERC
Postby support » 19 December 2013, 17:09
Please read this: viewtopic.php?f=11&t=551
This might be the problem.
Return to Editor
