Crossfade [fixed]
create lighting scenes
Crossfade [fixed]
Postby lvance » 27 March 2012, 20:16
I have searched the forums and can't find the "crossfade demo" mentioned in one of the posts.
I am new to the software and just getting up to speed, but I am finding it very difficult to create a simple crossfade between 3 groups of par cans.
Any assisance would be greatly appreciated!
lvance
Re: Crossfade
Postby tomrbland » 29 March 2012, 14:25
In editor at the bottom of each active channel there is a little "step" if you press this it should turn to a ramp. If you have two scenes with the little icons set as ramps, in Live if you trigger each scene they will fade between the two.
I hop this helps, sorry to not post a better explanation but I'm short on time. Good luck!
tomrbland
Re: Crossfade
Postby lvance » 01 May 2012, 17:45
Sorry for the delayed acknowledgement of your post! I found this and was able to make it work. Thank you!
lvance
Return to Editor
Users browsing this forum: No registered users and 3 guests
