High Sierra - crashes at starting [fixed]
Posted: 03 November 2017, 01:32
Need your help. Showxpress is not opening for me, every time I try and open the program I get “TheLightingController quit unexpectedly”. I’ve uninstalled and reinstalled showxpress and restarted my computer. Can’t seem to get it to work. Do you know of a solution?
Running: macOS High Sierra Version 10.13
Showxpress version 8.2.24
Here is the problem details and system configuration:
Process: TheLightingController [24426]
Path: /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [24426]
User ID: 501
Date/Time: 2017-11-02 20:26:14.326 -0400
OS Version: Mac OS X 10.13 (17A405)
Report Version: 12
Bridge OS Version: 3.0 (14Y661)
Anonymous UUID: 0D3606D1-13DB-3607-7487-C1CAE4721CE7
Sleep/Wake UUID: E487386B-2A85-4FE3-BDF6-9D690BBAC848
Time Awake Since Boot: 97000 seconds
Time Since Wake: 98 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
__TEXT 0000000000001000-00000000001ec000 [ 1964K] r-x/rwx SM=COW G [/Volumes/ShowXpress_Mac 1/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 efk_usb.dylib 0x003f3573 CDeviceHandle::CDeviceHandle(unsigned int) + 501
1 efk_usb.dylib 0x003f2c5e CallbackHook(void*, unsigned int) + 78
2 efk_usb.dylib 0x003f2d11 usbCallbackConnect + 91
3 efk_hardware.dylib 0x05303c3c EFK_check_hardware + 744
Thread 1:
0 libsystem_kernel.dylib 0xa764471a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0xa77710a0 _pthread_wqthread + 1536
2 libsystem_pthread.dylib 0xa7770a7a start_wqthread + 34
Thread 2:
Thread 3:
1 libsystem_pthread.dylib 0xa7770e80 _pthread_wqthread + 992
Thread 4:
1 libsystem_pthread.dylib 0xa7770eab _pthread_wqthread + 1035
Thread 5:
Thread 6:
Thread 7:
Thread 8:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0xa763ad22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0xa763a35f mach_msg + 47
2 com.apple.CoreFoundation 0x939016e8 __CFRunLoopServiceMachPort + 296
3 com.apple.CoreFoundation 0x939006d6 __CFRunLoopRun + 2262
4 com.apple.CoreFoundation 0x938ffad1 CFRunLoopRunSpecific + 641
5 com.apple.CoreFoundation 0x938ff83a CFRunLoopRunInMode + 122
6 com.apple.AppKit 0x91489095 _NSEventThread + 165
7 libsystem_pthread.dylib 0xa777151d _pthread_body + 347
8 libsystem_pthread.dylib 0xa77713c2 _pthread_start + 357
9 libsystem_pthread.dylib 0xa7770a9e thread_start + 34
Thread 9:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x003f3389 ecx: 0xa9a801f0 edx: 0x00012068
edi: 0x00514120 esi: 0x00514e80 ebp: 0xbffffa78 esp: 0xbffff9d0
ss: 0x00000023 efl: 0x00010282 eip: 0x003f3573 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x1ebff7 +TheLightingController (0.1) <9578A96A-6AA3-3DE8-A304-8C5EDD09322D> /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x365000 - 0x3aafcf dyld (519.2.1) <3FEC6B17-882D-32AA-9D24-CBD9B1FD18EA> /usr/lib/dyld
0x3f1000 - 0x3f3fff +efk_usb.dylib (1) <204D39A5-A168-521D-2EFF-8DD8DE656AC5> /Volumes/*/efk_usb.dylib
0x5300000 - 0x5320ffb +efk_hardware.dylib (0) <0F1950F0-6926-38D5-B52B-D947A63D1BED> /Volumes/*/efk_hardware.dylib
0x9099000 - 0x90a1ff7 com.apple.iokit.IOUSBLib (900.4.1 - 900.4.1) <E0935891-8DB3-3111-AC39-0B780DAA8C56> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x9200000 - 0x92c7fff com.apple.AMDRadeonX4000GLDriver (1.58.30 - 1.5.8) <5051E160-6126-324F-A8F5-2771B8BE4E3F> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0xa000000 - 0xaca3fff com.apple.driver.AppleIntelSKLGraphicsGLDriver (10.28.26 - 10.2.8) <03E45C76-1B10-326A-A2E2-AEECEFE55903> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
0xafce000 - 0xb6fcfff ATIRadeonX4000SCLib.dylib (1.58.30) <308197C7-1136-375C-819E-CB6C6BBC799C> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x9001d000 - 0x901d3ff3 com.apple.avfoundation (2.0 - 1334) <8D7020E4-09A5-3E52-AA0E-D6607F336791> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x901d4000 - 0x9028effb com.apple.audio.AVFAudio (1.0 - ???) <DE391193-A166-3916-8A14-7DBE68BC7ACA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x90290000 - 0x90290fff com.apple.Accelerate (1.11 - Accelerate 1.11) <65375A38-816E-3360-ADF5-F1D466EAE43B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90291000 - 0x902a7ffb libCGInterfaces.dylib (417) <92B03F58-1974-35E7-BC7F-28B6B285A860> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x902a8000 - 0x909e9fdf com.apple.vImage (8.1 - ???) <591C941E-6475-347E-89DA-F541E88F949A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x909ea000 - 0x90b25ff7 libBLAS.dylib (1211) <ECA7DF28-62AA-3A71-9D82-DB3A14553E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x90b26000 - 0x90b53ff7 libBNNS.dylib (32) <8761FEAA-6846-31F1-80AC-54315D61395F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x90b54000 - 0x90ec7fff libLAPACK.dylib (1211) <8B0949D5-035C-3216-9D15-17BA099DBF58> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90ec8000 - 0x90edeffb libLinearAlgebra.dylib (1211) <6ADA0BFE-3AAF-3430-8BD8-8C604EBEA81A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x90edf000 - 0x90ef8ff7 libSparseBLAS.dylib (1211) <0C7848B1-0F3B-3EB7-8784-57D15012D2B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x90ef9000 - 0x9104bfef libvDSP.dylib (622) <9C75C687-597F-38D3-8736-73D9F94A6430> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9104c000 - 0x9112aff7 libvMisc.dylib (622) <586BE48F-78E9-3EA7-9837-6B4F926613B1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9112b000 - 0x9112bfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D750F2CC-FDBC-3486-8BAD-6B828D4814BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9131a000 - 0x920daff7 com.apple.AppKit (6.9 - 1561.0.100) <F6F4335C-8380-3220-98FF-55822AE7D0D6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9212c000 - 0x9212cfff com.apple.ApplicationServices (48 - 50) <7557388A-2C5B-3467-8793-D56E4B57A1FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9212d000 - 0x92193ff3 com.apple.ApplicationServices.ATS (377 - 445) <1C8196A6-CF4F-3E08-B067-61B870F72DA3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92196000 - 0x922baff3 libFontParser.dylib (222.1) <EF22371D-9F4F-3F8F-8935-748B5360F69C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x922bb000 - 0x92307ffb libFontRegistry.dylib (221) <8D81FDCF-F05D-3556-AB6D-090F9508C25E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92356000 - 0x92389fff libTrueTypeScaler.dylib (222.1) <486F15D0-6314-3730-82AD-CB338560C506> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x923f5000 - 0x923fafff com.apple.ColorSyncLegacy (4.13.0 - 1) <2210061E-63BC-3B26-B8AE-560DC457F127> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x924a4000 - 0x924fbff7 com.apple.HIServices (1.22 - 622) <8544026A-17BE-301D-BA2A-782F3AD864DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x924fc000 - 0x9250bff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <E3245701-039B-353F-923D-F81B2242842C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9250c000 - 0x92564ffb com.apple.print.framework.PrintCore (13 - 503) <FCCA7283-94EC-3D6C-B962-6B4CDD50D9A7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92565000 - 0x925fbffb com.apple.QD (3.12 - 403) <372AFF26-17D1-3C6F-9E47-17C955C2045B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x925fc000 - 0x92608ff3 com.apple.speech.synthesis.framework (7.0.14 - 7.0.14) <F0AAFDF5-3254-3F8B-9575-6F972A179131> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92609000 - 0x92853ffb com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <3D8460F9-6192-3983-83F8-7D2AE16D2DA1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92855000 - 0x92855fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <146E2F6D-A64B-3AC4-99C0-857700540696> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92b74000 - 0x92eb3ff7 com.apple.CFNetwork (887 - 887) <379FD334-1AF6-3FA4-8B7C-890995AEC4F0> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92ec8000 - 0x92ec8fff com.apple.Carbon (158 - 158) <83C4D410-E216-3EAC-A663-94645F4BCB86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92ec9000 - 0x92ed2ff3 com.apple.audio.SoundManager (4.2 - 4.2) <83AE7AA9-8661-3449-99F4-291A42640692> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92ed3000 - 0x92ed7fff com.apple.CommonPanels (1.2.6 - 98) <DA1D99A4-53F6-31AF-964D-86739FA74B52> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92ed8000 - 0x9326dff7 com.apple.HIToolbox (2.1.1 - 909.1) <2AF1ACB9-424B-38FD-B15C-06AB6D2BAF4F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9326e000 - 0x932c2ffb com.apple.htmlrendering (77 - 1.1.4) <BAF5C846-FF50-3C80-97F5-71F1399CA85C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x932c3000 - 0x932c6fff com.apple.help (1.3.8 - 64) <1E913488-5D7B-388E-904D-64EF8C99E704> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x932c7000 - 0x932ccffb com.apple.ImageCapture (9.0 - 9.0) <1887749B-D641-3057-B91F-3C2D8E990115> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x932cd000 - 0x93367ffb com.apple.ink.framework (10.9 - 220) <5340E055-BD3D-35AD-9797-F22E1ECEDAC6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93368000 - 0x933a2fff com.apple.NavigationServices (3.8 - 227) <6B1000C3-9C00-33F5-88D5-62F6BD5DD7F8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x933a3000 - 0x933beffb com.apple.openscripting (1.7 - 174) <DFBC4482-0915-3C4F-8C9A-7A7A1620C3B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x933bf000 - 0x933c4fff com.apple.print.framework.Print (12 - 267) <F7BEF8BA-7D1F-34A2-97B8-D49F20886644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x933c5000 - 0x933c7fff com.apple.securityhi (9.0 - 55006) <E9FF8254-B8E1-312A-8FC3-2B4EA8CE9AEA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x933c8000 - 0x933cefff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C27FB7B-A467-3171-A73B-8C9B403028E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x933cf000 - 0x933cffff com.apple.Cocoa (6.11 - 22) <83D0A833-FD91-364B-AA4C-B5FCEB7F66BF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x933dc000 - 0x9349bff7 com.apple.ColorSync (4.13.0 - 544) <AA55BFD7-A5AD-35AC-B64B-93A798EBED1D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9349c000 - 0x93537fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <9D1B217E-03F6-38F6-B737-DE5D5DC6DA15> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93595000 - 0x9359afff com.apple.CoreBluetooth (1.0 - 1) <E0F40A70-9E04-31FE-A4C8-BE05F6432BAD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x9359b000 - 0x9387afff com.apple.CoreData (120 - 847.1) <2AC013DC-8148-34C9-89B1-41353CAECD7F> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9387b000 - 0x93881ff3 com.apple.CoreDisplay (1.0 - 79.7) <98FDF833-62E9-38D3-8155-40A184276A61> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x93882000 - 0x93d0aff7 com.apple.CoreFoundation (6.9 - 1443.13) <31DD4E52-D928-3CF8-BA35-B0080DDBC424> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93d0c000 - 0x9433affb com.apple.CoreGraphics (2.0 - 1125.1.1) <4F472247-7953-3DD7-88A4-8DB0065ECC0C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9433c000 - 0x945c1ffb com.apple.CoreImage (13.0.0 - 573) <6D197299-898E-3BAD-ABB6-444800945B50> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x94633000 - 0x94679fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <545850CB-096A-37E3-8FDB-0640B5D222E6> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x9467c000 - 0x94758ff7 com.apple.CoreMedia (1.0 - 2074.3) <9FBB254B-E142-37EB-98C5-0E851FC5D431> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x94759000 - 0x947abfff com.apple.CoreMediaIO (803.0 - 4976) <A51DE163-E26A-3186-AB73-07B7181D8AF0> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x947ac000 - 0x947acfff com.apple.CoreServices (822.9 - 822.9) <717212C8-310C-3DDF-8CC9-F0BC46A25225> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x947ad000 - 0x9481ffff com.apple.AE (733 - 733) <C981EE72-993D-3E0A-AB53-47ABB7C57EE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94820000 - 0x94afeffb com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <E61EA71D-294F-3C8B-95BD-0CDBA0FFC907> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94aff000 - 0x94b33ff3 com.apple.DictionaryServices (1.2 - 284) <56BEF6B8-50D2-38A0-9EF2-D7093E9AAB56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94b34000 - 0x94b3cfff com.apple.CoreServices.FSEvents (1239 - 1239) <CABC21F7-E3AB-3954-ACBE-B8066A37516A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x94b3d000 - 0x94c9aff7 com.apple.LaunchServices (822.9 - 822.9) <76540FA9-7B3C-3747-BC45-FF2809B479A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94c9b000 - 0x94d47ff7 com.apple.Metadata (10.7.0 - 1191) <A1BA6522-F4E3-31AD-8E3D-64A26F2B6200> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94d48000 - 0x94da6ff3 com.apple.CoreServices.OSServices (822.9 - 822.9) <463DB8DD-1A42-33AC-B12F-2A2C982F0C6A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x94da7000 - 0x94e18ff3 com.apple.SearchKit (1.4.0 - 1.4.0) <FAD60011-970B-3889-B6BD-3715CCF599CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94e19000 - 0x94e3cfff com.apple.coreservices.SharedFileList (71.2 - 71.2) <7384B131-3CCF-3F40-8BE4-090B05C3D38A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x94e3d000 - 0x94f87ff7 com.apple.CoreText (352.0 - 578.3) <8165D2A6-0A1B-3DE7-81B6-F9DCCE480BA6> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x94f88000 - 0x94fc2ff3 com.apple.CoreVideo (1.8 - 278.0) <D6EF38C6-9ECF-3DDC-BAE5-BA8FFA63A2CB> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94fc3000 - 0x95049ff3 com.apple.framework.CoreWLAN (13.0 - 1335) <54FE3AB9-A361-3D5D-AC9F-9C654AFDECAB> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x9529d000 - 0x952a6ff7 com.apple.DiskArbitration (2.7 - 2.7) <E3552A79-57A4-36AE-8B54-5FE2EB5193DA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x952b7000 - 0x95624ff7 com.apple.Foundation (6.9 - 1443.14) <2D74E68D-2034-309B-B8B0-E7975A52BA23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95665000 - 0x95694fff com.apple.GSS (4.0 - 2.0) <09F9AD7C-8FD8-3660-9AD4-C6610689682B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x956c0000 - 0x957d7ff7 com.apple.Bluetooth (6.0.0 - 6.0.0f7) <1005CBBF-C447-33C8-BC90-0E85A1BC0536> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x9583f000 - 0x958dfffb com.apple.framework.IOKit (2.0.2 - 1445.1.3) <7D7DD393-BCA5-3E91-8F97-5968CBFC7D3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x958e1000 - 0x958e7fff com.apple.IOSurface (209 - 209) <CEB65557-BBAB-3233-ABCB-2AE4104DD876> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9593b000 - 0x95ab8fff com.apple.ImageIO.framework (3.3.0 - 1694) <58E20069-1F71-3D8C-98EC-7B68BDCFDECD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95ab9000 - 0x95abdffb libGIF.dylib (1694) <39E7C8B4-47DC-3894-87C6-860EA24E243C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95abe000 - 0x95baffff libJP2.dylib (1694) <184F41CE-3897-3F7C-8666-F77829CA9677> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95bb0000 - 0x95bd2ff7 libJPEG.dylib (1694) <CA457944-109E-35B5-B558-011724EC63DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95eb3000 - 0x95ed9ff7 libPng.dylib (1694) <60381815-963F-31FB-9947-0B677E6C8D78> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95eda000 - 0x95edcffb libRadiance.dylib (1694) <620092C3-DB38-3962-967E-34F65C3EE97B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95edd000 - 0x95f27ff3 libTIFF.dylib (1694) <A5E2A4FB-BEE4-3D4E-B80E-5342B6BC02D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95fd5000 - 0x96803ff7 com.apple.JavaScriptCore (13604 - 13604.1.38.1.6) <9D384BD6-E3B9-3D40-8FD3-D72AC358FB8F> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9681b000 - 0x96833fff com.apple.Kerberos (3.0 - 1) <8A399DB7-5440-3EC0-A241-3DD10E82DDB2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9688b000 - 0x96893fff com.apple.MediaAccessibility (1.0 - 114) <087BD9A6-6E5E-3884-B4F7-8F0A6B662B8D> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x96894000 - 0x96e89ffb com.apple.MediaToolbox (1.0 - 2074.3) <D9CFE9AF-DFC9-3175-BBE4-5A9CA618176F> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x96e8b000 - 0x96f01ff7 com.apple.Metal (123.3.5 - 123.3.5) <9F8F2C16-236A-39CA-A11F-8D762DB4E37C> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x96f03000 - 0x96f0ffff com.apple.NetFS (6.0 - 4.0) <F37A4DA0-AAB6-3F0B-BA18-E322BFA52CC4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x99c43000 - 0x99c4bff7 libcldcpuengine.dylib (2.8.7) <E3B50B98-E1E4-396C-BB05-935AACC6FD80> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x99c4c000 - 0x99c97fff com.apple.opencl (2.8.11 - 2.8.11) <A91D3A7A-EACD-3F44-897C-C6DB723CEC03> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x99c98000 - 0x99cb4fff com.apple.CFOpenDirectory (10.13 - 207) <703506C0-FE72-36F3-990A-76A72064B3B9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x99cb5000 - 0x99cc0fff com.apple.OpenDirectory (10.13 - 207) <F5BED4FF-26F2-3580-93ED-4F6B27D99E2F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9aeca000 - 0x9aecbfff libCVMSPluginSupport.dylib (16.0.3) <421F979D-C793-32E1-B84E-09AAA2F0EE44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9aecc000 - 0x9aecffff libCoreFSCache.dylib (160.9) <A16ACDE7-22D4-362D-98A8-023F3D61989C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x9aed0000 - 0x9aed4fff libCoreVMClient.dylib (160.9) <B8BD8FDA-0A77-3668-AA68-ADE5910BAB14> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9aed5000 - 0x9aeddff7 libGFXShared.dylib (16.0.3) <8448CB42-18AE-3279-B11B-ECD74AA1ECC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9aede000 - 0x9aeeafff libGL.dylib (16.0.3) <B10792CA-814B-3E00-9D1A-626C2CBCEEC7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9aeeb000 - 0x9af26ffb libGLImage.dylib (16.0.3) <A071BC79-94CE-3075-8139-154A576AFAA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9af27000 - 0x9b09fffb libGLProgrammability.dylib (16.0.3) <D5B975A4-D735-3ECD-BE1D-8FF351C37F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9b0a0000 - 0x9b0e2ff7 libGLU.dylib (16.0.3) <2614C4B3-A4D2-39CA-9480-46E376546391> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9ba89000 - 0x9ba97fff com.apple.opengl (16.0.3 - 16.0.3) <CCA4EA13-DBF6-314D-A6AE-0C273393B425> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9ba98000 - 0x9bc25ffb GLEngine (16.0.3) <89092021-3FE7-300B-AFFF-033408721599> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x9bc26000 - 0x9bc50fff GLRendererFloat (16.0.3) <76940B7B-2617-3789-A277-2B30389E7A51> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x9bd6e000 - 0x9bebfffb com.apple.QTKit (7.7.3 - 3014) <9DB2668A-3F68-32F0-BF51-C7F791FEE8EE> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9c806000 - 0x9ca37fff com.apple.QuartzCore (1.11 - 574.1.4) <22685244-B08A-3BA4-83EB-7097E0AAA52B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9ca8d000 - 0x9cce5feb com.apple.QuickTime (7.7.3 - 3014) <A38CF029-378C-3D67-9359-7DC15452B0E4> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9cecd000 - 0x9d200ff3 com.apple.security (7.0 - 58286.1.33) <97C1F7D1-10BD-3A08-98DF-258892DF64CF> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9d201000 - 0x9d287ff3 com.apple.securityfoundation (6.0 - 55185.1.1) <0CAAFA4B-8779-3927-AB0F-DA6BA8AF12EF> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9d2b0000 - 0x9d2b4fff com.apple.xpc.ServiceManagement (1.0 - 1) <C830416D-0D84-303D-A2BD-1A186B193DF9> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x9d3dd000 - 0x9d44dffb com.apple.SystemConfiguration (1.17 - 1.17) <C03891C9-927C-3433-BB6E-9103D7A37D06> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9d5f7000 - 0x9d982fff com.apple.VideoToolbox (1.0 - 2074.3) <D4FEC64B-7282-3655-93EC-850BB5B5885A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x9d983000 - 0x9ed2fffb com.apple.WebCore (13604 - 13604.1.38.1.6) <0FC2DF17-1806-39F8-ABCD-A74EFF243524> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9ed30000 - 0x9eec2ffb com.apple.WebKitLegacy (13604 - 13604.1.38.1.6) <40828462-3F33-3D4D-B2FE-0C8BAB45F99A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x9eec3000 - 0x9f1feff7 com.apple.WebKit (13604 - 13604.1.38.1.6) <F24FDE02-8F4B-3F30-97EB-8DF0E90E6EAA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9f210000 - 0x9f2a4ff7 com.apple.APFS (1.0 - 1) <6AE092B7-C6A3-3B08-83CA-531CF4842EBE> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x9f88f000 - 0x9f8baff3 com.apple.framework.Apple80211 (13.0 - 1335) <729DBF0C-4F9E-3DA3-8883-4E8FB59D7560> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9f8bc000 - 0x9f8c6fff com.apple.AppleFSCompression (96.1.1 - 1.0) <38FA63FB-6E9E-3382-80E2-111F42CB1EE3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x9f9bd000 - 0x9f9fafff com.apple.AppleJPEG (1.0 - 1) <A79335BD-B17F-3340-B5AD-2230B83878C0> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9faf4000 - 0x9fb43ffb com.apple.AppleVAFramework (5.0.39 - 5.0.39) <89895B3A-FA16-35EC-9A2C-22AF1A311A1D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9fb4d000 - 0x9fb54fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <3CEE4D97-2EAB-3400-A31D-92D2E3D8088C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x9fb55000 - 0x9fbe0ffb com.apple.backup.framework (1.9 - 1.9) <C71A70C4-F474-363C-BD15-383C5BC311CA> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9fd23000 - 0x9fd2cfff com.apple.CommonAuth (4.0 - 2.0) <17A264D0-9611-33EA-9081-6CA2E277655C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9fdd5000 - 0xa00edfef com.apple.CoreAUC (249.0.0 - 249.0.0) <77A27B7D-9EB4-39E0-9411-C9B7BDF0B1A8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0xa00ee000 - 0xa011ffff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <EC1E91A7-CFD3-31E4-AE53-1D57BC7F852A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0xa019d000 - 0xa01adfff com.apple.CoreEmoji (1.0 - 69) <1183DFFF-DC0E-33CF-A261-0E0308CE5FDC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0xa01ae000 - 0xa01c4ff7 com.apple.CoreMediaAuthoring (2.2 - 956) <7FB86A4B-5DC0-3267-AC40-3A99436D3FF1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0xa032b000 - 0xa035eff7 com.apple.CoreServicesInternal (309 - 309) <C26C43BC-891C-3A34-8DDC-6C5356BB56CE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0xa035f000 - 0xa03f5ff3 com.apple.CoreSymbolication (63075) <82E57290-F924-321F-97A4-E158434B4A19> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0xa03f6000 - 0xa051cfeb com.apple.coreui (2.1 - 489) <D162F5FC-E903-36EF-B10C-9CA674F543A1> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0xa051d000 - 0xa05b7fff com.apple.CoreUtils (5.2 - 520.68) <86913493-85C4-380B-82FF-81D160E1FE1F> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0xa0608000 - 0xa0665ff3 com.apple.framework.CoreWiFi (13.0 - 1335) <6EFABB25-6759-34B1-98CD-87421E393A86> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0xa0666000 - 0xa0676fff com.apple.CrashReporterSupport (10.13 - 1) <D65CA840-BAD7-3D1E-A245-C8F3E5320DEA> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0xa06e4000 - 0xa06f1fff com.apple.framework.DFRFoundation (1.0 - 189.1) <53CE2E61-9ECE-339E-94E7-3E428A9142B4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0xa073e000 - 0xa07aefff com.apple.datadetectorscore (7.0 - 590) <9634322F-D458-3964-8A01-CE39FD33D64C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0xa07af000 - 0xa07efffb com.apple.DebugSymbols (141 - 141) <96BB879B-1A83-3622-BB02-1DDA5C4FD939> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0xa07f0000 - 0xa0928ff3 com.apple.desktopservices (1.12 - 1.12) <FB7D558C-0C67-304B-9778-35CA9624EB02> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0xa0bf3000 - 0xa1023ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <B2288C3D-E67F-3AAE-A652-E920CD19F267> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0xa2dcd000 - 0xa2dd7fff libGPUSupportMercury.dylib (16.0.3) <C17E1EC3-4DAB-3F2B-B999-D6461CBB04F4> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0xa39bd000 - 0xa3a30ff3 com.apple.Heimdal (4.0 - 2.0) <2A215F01-C54B-3386-A731-2C92B26B50E6> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0xa3cdf000 - 0xa3ce5fff com.apple.IOAccelerator (373 - 373) <C3D082C6-4EDC-35F4-A1EF-FA9C837B330B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0xa3ce6000 - 0xa3cfefff com.apple.IOPresentment (1.0 - 32.1) <808BF662-E235-31F1-95C6-D8657A259BA3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0xa3d5b000 - 0xa3d7aff3 com.apple.IconServices (97.3 - 97.3) <B8BBEF67-8A6A-3F6D-A859-4E893CF3262F> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0xa3d83000 - 0xa3d92fff com.apple.IntlPreferences (2.0 - 227) <530C7334-9F93-322A-9F4B-E449922F2498> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0xa3db2000 - 0xa3ea6fff com.apple.LanguageModeling (1.0 - 159) <72552B38-94F9-3579-BCA6-FA67599D7FC5> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0xa3ea7000 - 0xa3ee8ff3 com.apple.Lexicon-framework (1.0 - 33) <68E2818A-D287-3765-BD97-751D40D82697> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0xa3eec000 - 0xa3ef2ffb com.apple.LinguisticData (1.0 - 238) <DADD1591-7608-3B63-951B-9BA8931BDE60> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0xa429e000 - 0xa42c7ffb com.apple.MultitouchSupport.framework (1004.1 - 1004.1) <ABA83552-FA26-31D3-9C32-5C7D24157ADF> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0xa43e6000 - 0xa43f0fff com.apple.NetAuth (6.2 - 6.2) <52F67DC1-8C96-3944-8E54-C02DD51FD9FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0xa4498000 - 0xa44d4fff com.apple.PerformanceAnalysis (1.183 - 183) <52CA4DBF-4C1D-3D30-8FD4-EF595C1B6C71> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0xa4572000 - 0xa458eff7 com.apple.ProtocolBuffer (1 - 259) <BBB59E09-0B06-3262-9C81-C126DF34667C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0xa467a000 - 0xa469cfff com.apple.RemoteViewServices (2.0 - 125) <5720B413-E761-3368-964F-7FEAC5535669> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0xa4752000 - 0xa477effb com.apple.Sharing (910.7 - 910.7) <F232ED72-400D-35E4-8089-FAF1036E6FEB> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0xa479d000 - 0xa479efff com.apple.performance.SignpostNotification (1.0 - 1) <5B9FAEF5-EB02-3B2A-AC6E-1E80AA59A7F1> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0xa479f000 - 0xa4824ff3 com.apple.SkyLight (1.600.0 - 312) <0F1157F0-97A0-3527-B177-4A2B9F925C67> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0xa4854000 - 0xa4861ffb com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <BACA23B0-AF15-3B7F-8933-15DDEE48318B> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0xa4b2e000 - 0xa4bafff3 com.apple.Symbolication (9.0 - 63079.1) <97DA4973-352E-3CBA-9B4A-BC22C3AFD597> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0xa4c02000 - 0xa4c09fff com.apple.TCC (1.0 - 1) <8E4DD699-FE42-3B8E-AE2D-FB9AD29C927B> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0xa4c0a000 - 0xa4c21ff3 com.apple.TextureIO (3.4 - 3.4) <5C14EC48-1C46-39E3-ACB5-ADA3F7E2BFA8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0xa4c48000 - 0xa4c49fff com.apple.TrustEvaluationAgent (2.0 - 31) <185BD5A9-5A2D-3317-B7FE-9B67F14C4D2C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0xa4c4a000 - 0xa4dd4fff com.apple.UIFoundation (1.0 - 543) <2B11011C-CECA-309F-8D02-6DA6B38AA6FD> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0xa53a2000 - 0xa53a4fff com.apple.loginsupport (1.0 - 1) <086FAE1B-87E2-324A-AE76-E6EC0B5F1517> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0xa542f000 - 0xa5462ff7 libclosured.dylib (519.2.1) <1C4AD77C-926A-3BD9-B8A2-81BC766497C9> /usr/lib/closure/libclosured.dylib
0xa54b2000 - 0xa54e9ff3 libCRFSuite.dylib (41) <7F584902-74F1-3362-935D-95F5E735F5E7> /usr/lib/libCRFSuite.dylib
0xa54ea000 - 0xa54f4ffb libChineseTokenizer.dylib (28) <1FF5A32D-E012-3E76-B738-FAC26AD2A39B> /usr/lib/libChineseTokenizer.dylib
0xa5590000 - 0xa5591fff libDiagnosticMessagesClient.dylib (104) <6829B180-2556-3A7E-A2E6-BD4859DF30A7> /usr/lib/libDiagnosticMessagesClient.dylib
0xa55c3000 - 0xa57adff7 libFosl_dynamic.dylib (17.7) <DBE4D720-8A46-3879-AD2D-F9A8CE3E7476> /usr/lib/libFosl_dynamic.dylib
0xa57b5000 - 0xa57b5fff libOpenScriptingUtil.dylib (174) <B7CEDC30-2D17-3896-9EFC-64DB3D11DF00> /usr/lib/libOpenScriptingUtil.dylib
0xa57fe000 - 0xa5802fff libScreenReader.dylib (562.1) <A2A66CC0-780C-3751-AC41-075118B8EF14> /usr/lib/libScreenReader.dylib
0xa5803000 - 0xa5804fff libSystem.B.dylib (1252) <96309D00-55F1-36DB-9A6B-94DE5E7167E4> /usr/lib/libSystem.B.dylib
0xa5813000 - 0xa5828ff7 libapple_nghttp2.dylib (1.24) <480C0C04-2533-3D44-8232-006B6CBA7758> /usr/lib/libapple_nghttp2.dylib
0xa5829000 - 0xa5854fff libarchive.2.dylib (54) <D55C5F86-251D-3C33-A617-0C623D4F512E> /usr/lib/libarchive.2.dylib
0xa5855000 - 0xa59a4ffb libate.dylib (1.13.1) <E109CCBF-357D-3C87-9CE5-D53AE03609A2> /usr/lib/libate.dylib
0xa59a8000 - 0xa59a8ff3 libauto.dylib (187) <CE2A78CC-670F-3E07-9539-822DCD2F6084> /usr/lib/libauto.dylib
0xa59a9000 - 0xa59b9fff libbsm.0.dylib (39) <067E9003-0673-32A3-9B40-492323182C5C> /usr/lib/libbsm.0.dylib
0xa59ba000 - 0xa59c6ff7 libbz2.1.0.dylib (38) <77C24A36-BE84-3702-A786-935C597A0A86> /usr/lib/libbz2.1.0.dylib
0xa59c7000 - 0xa5a20ffb libc++.1.dylib (400.9) <AD612EEF-6CE3-315D-82C2-58248BE13431> /usr/lib/libc++.1.dylib
0xa5a21000 - 0xa5a42fff libc++abi.dylib (400.7) <41323E53-C7EA-3E9A-BD30-38E82399F843> /usr/lib/libc++abi.dylib
0xa5a44000 - 0xa5a55ff7 libcmph.dylib (6) <EC7664F1-B5A1-37F4-B7DC-F6AC10587E35> /usr/lib/libcmph.dylib
0xa5a56000 - 0xa5a69ff7 libcompression.dylib (47) <F80DDFC1-F96A-3BAD-967D-C1E24253273A> /usr/lib/libcompression.dylib
0xa5a6a000 - 0xa5a81ffb libcoretls.dylib (155) <F66FAEBC-4B6E-31E0-ACA8-C8ACBC7689DD> /usr/lib/libcoretls.dylib
0xa5a82000 - 0xa5a83fff libcoretls_cfhelpers.dylib (155) <8B8ABC2C-F251-3C80-9747-88C05A2CBE64> /usr/lib/libcoretls_cfhelpers.dylib
0xa5c04000 - 0xa5dabfff libcrypto.35.dylib (22) <EE1BA2F7-F2F4-387B-8866-5B4A7023D29F> /usr/lib/libcrypto.35.dylib
0xa5f6b000 - 0xa5fc2fff libcups.2.dylib (462) <0EF67F4A-8E0A-3349-9259-5AC3D65143D6> /usr/lib/libcups.2.dylib
0xa60d8000 - 0xa60d8fff libenergytrace.dylib (16) <34FC43C7-D9B6-3C01-8B65-E49059D31279> /usr/lib/libenergytrace.dylib
0xa60d9000 - 0xa60f0ffb libexpat.1.dylib (16.1.1) <3E73B1C8-216F-3E94-83AE-59559365D2DD> /usr/lib/libexpat.1.dylib
0xa610c000 - 0xa6110fff libheimdal-asn1.dylib (520) <506DE95C-3CB0-33ED-9DC0-B5D4665BE010> /usr/lib/libheimdal-asn1.dylib
0xa613c000 - 0xa622cff3 libiconv.2.dylib (51) <FE6D05A5-18DB-3FD8-A52F-B7BADB232C78> /usr/lib/libiconv.2.dylib
0xa622d000 - 0xa644fffb libicucore.A.dylib (59117.0.1) <8D56A4D5-C688-36AE-853E-875C09164234> /usr/lib/libicucore.A.dylib
0xa6497000 - 0xa6498fff liblangid.dylib (128) <120FE992-47E4-3A73-A039-1B401F5696DC> /usr/lib/liblangid.dylib
0xa6499000 - 0xa64b1ff7 liblzma.5.dylib (10) <8A5C9679-430A-3A19-AF68-9D21BAC442C7> /usr/lib/liblzma.5.dylib
0xa64b2000 - 0xa64c7fff libmarisa.dylib (9) <805453EE-B829-3DA5-8DF3-5132D03D5B74> /usr/lib/libmarisa.dylib
0xa657c000 - 0xa6798fff libmecabra.dylib (779.1) <07D38CF9-A4A2-35D1-A996-E7F29BD561E1> /usr/lib/libmecabra.dylib
0xa695f000 - 0xa6a32ff3 libnetwork.dylib (1229.1.5) <A9164BB1-E070-3D48-96A4-E77BB351B18A> /usr/lib/libnetwork.dylib
0xa6a33000 - 0xa6e130fb libobjc.A.dylib (723) <4AF346B8-C1A8-3199-B1BB-ADEDD64D5C1A> /usr/lib/libobjc.A.dylib
0xa6e17000 - 0xa6e1afff libpam.2.dylib (22) <7106F43C-84DD-3F26-905A-B52780AFEB3E> /usr/lib/libpam.2.dylib
0xa6e1d000 - 0xa6e4efff libpcap.A.dylib (79) <178094CE-BF5A-3C92-9A74-525AA907FA21> /usr/lib/libpcap.A.dylib
0xa6e8c000 - 0xa6ea7ffb libresolv.9.dylib (65) <65A43F5B-CF88-3948-AE5C-D7CA02D814A1> /usr/lib/libresolv.9.dylib
0xa6ef2000 - 0xa707ffff libsqlite3.dylib (274.1) <6EDB0451-67F8-3870-8EF9-50346FC26669> /usr/lib/libsqlite3.dylib
0xa718f000 - 0xa71dfffb libstdc++.6.0.9.dylib (104.1) <74744B76-524A-3052-A4CF-3C47446A32C0> /usr/lib/libstdc++.6.0.9.dylib
0xa7223000 - 0xa725dffb libusrtcp.dylib (1229.1.5) <28CC4C32-DAFF-3C05-A288-97EA513DC10D> /usr/lib/libusrtcp.dylib
0xa725e000 - 0xa7261fff libutil.dylib (51) <C041EF3C-8E30-3F43-BCE2-7DA3E3673A8A> /usr/lib/libutil.dylib
0xa7262000 - 0xa7270ff7 libxar.1.dylib (400) <4B664A7E-EC05-34AD-ACC6-C879B69DBA7C> /usr/lib/libxar.1.dylib
0xa7271000 - 0xa734fff7 libxml2.2.dylib (31.7) <3E1F9E3D-6C44-3437-AB2B-E5ACE1927F81> /usr/lib/libxml2.2.dylib
0xa7350000 - 0xa7378ff3 libxslt.1.dylib (15.10) <1A3DC7B8-7C92-3D73-BF82-D60E64BC3DF0> /usr/lib/libxslt.1.dylib
0xa7379000 - 0xa7388ff7 libz.1.dylib (70) <588F445F-0065-3D77-8002-BA9411DA1D70> /usr/lib/libz.1.dylib
0xa73c1000 - 0xa73c5fff libcache.dylib (80) <5D011637-CADA-38A1-A695-CE049657FD9D> /usr/lib/system/libcache.dylib
0xa73c6000 - 0xa73d0fff libcommonCrypto.dylib (60118.1.1) <536D7954-7C70-368F-BF63-A02A4E4529D6> /usr/lib/system/libcommonCrypto.dylib
0xa73d1000 - 0xa73d6fff libcompiler_rt.dylib (62) <FA07FEE2-CEFE-3CC0-A82F-E601AA2CCB36> /usr/lib/system/libcompiler_rt.dylib
0xa73d7000 - 0xa73e0ff7 libcopyfile.dylib (146) <13E84219-DA7C-3774-BB84-56CB93C8C8BB> /usr/lib/system/libcopyfile.dylib
0xa73e1000 - 0xa7448fff libcorecrypto.dylib (562) <FF27DFD5-EEF0-3045-87D0-28F746007FB2> /usr/lib/system/libcorecrypto.dylib
0xa74b2000 - 0xa74e7ffb libdispatch.dylib (913.1.6) <6C6E14A6-E999-3E7B-AD06-A258FC5B2ED1> /usr/lib/system/libdispatch.dylib
0xa74e8000 - 0xa7505fff libdyld.dylib (519.2.1) <85A28A4C-AFE5-3A7E-A16D-10C304A86040> /usr/lib/system/libdyld.dylib
0xa7506000 - 0xa7506fff libkeymgr.dylib (28) <C448ACFC-DD1B-3F08-B4C3-D2B69D1210B1> /usr/lib/system/libkeymgr.dylib
0xa7507000 - 0xa7513ff7 libkxld.dylib (4570.1.46) <6C86E320-D9FE-3DE1-8EAE-88D0115FCD84> /usr/lib/system/libkxld.dylib
0xa7514000 - 0xa7514fff liblaunch.dylib (1205.1.10) <4C5BA334-9EA5-3EFA-8C2D-BD4A234978E4> /usr/lib/system/liblaunch.dylib
0xa7515000 - 0xa751afff libmacho.dylib (900.0.1) <F1F0BC1D-A2D9-39F9-9A11-263F8392CB3B> /usr/lib/system/libmacho.dylib
0xa751b000 - 0xa751dfff libquarantine.dylib (86) <68DE2EB2-7911-304D-89D6-1517CA689001> /usr/lib/system/libquarantine.dylib
0xa751e000 - 0xa751ffff libremovefile.dylib (45) <BEF76B44-53EA-3970-AB50-2296DC7F097F> /usr/lib/system/libremovefile.dylib
0xa7520000 - 0xa7537ff7 libsystem_asl.dylib (356.1.1) <F96973B5-C36B-3037-8AEC-3BF7147D79E2> /usr/lib/system/libsystem_asl.dylib
0xa7538000 - 0xa7538fff libsystem_blocks.dylib (67) <32CE9BB7-E047-3568-981E-4EA94D3DCBB5> /usr/lib/system/libsystem_blocks.dylib
0xa7539000 - 0xa75c5fff libsystem_c.dylib (1244.1.7) <5303B1D1-214D-357C-B08E-AD7500A4133D> /usr/lib/system/libsystem_c.dylib
0xa75c6000 - 0xa75c9fff libsystem_configuration.dylib (963) <A8287AD3-977A-314C-9F75-039A68BD3617> /usr/lib/system/libsystem_configuration.dylib
0xa75ca000 - 0xa75cdfff libsystem_coreservices.dylib (51) <C3D75760-EED5-3C5C-8245-FBD3D9FD60FD> /usr/lib/system/libsystem_coreservices.dylib
0xa75ce000 - 0xa75cffff libsystem_darwin.dylib (1244.1.7) <CDB623E2-9A63-345D-82A0-931EEB5C5B0A> /usr/lib/system/libsystem_darwin.dylib
0xa75d0000 - 0xa75d6ff3 libsystem_dnssd.dylib (878.1.1) <3C00C266-30F6-3DAC-8D54-4504BE6AB9F7> /usr/lib/system/libsystem_dnssd.dylib
0xa75d7000 - 0xa7626ffb libsystem_info.dylib (517) <2EAFB95B-E88C-3D83-8254-4E829D30D95A> /usr/lib/system/libsystem_info.dylib
0xa7627000 - 0xa764aff3 libsystem_kernel.dylib (4570.1.46) <DF6AC242-99E5-3B7B-A4AD-E6A652FD6BC1> /usr/lib/system/libsystem_kernel.dylib
0xa764b000 - 0xa769afdb libsystem_m.dylib (3146) <DBE0AACD-3665-3EEB-BADA-A435E591C54B> /usr/lib/system/libsystem_m.dylib
0xa769b000 - 0xa76b5fff libsystem_malloc.dylib (140.1.1) <DFE0206A-865E-359D-B2F9-FE9DBB3B5B32> /usr/lib/system/libsystem_malloc.dylib
0xa76b6000 - 0xa7752fff libsystem_network.dylib (1229.1.5) <4B88E3E9-7C28-3BBE-8143-5579FE6A71EF> /usr/lib/system/libsystem_network.dylib
0xa7753000 - 0xa775dfff libsystem_networkextension.dylib (767.1.4) <92CBAB05-8D30-3405-92B2-9D92966B2D33> /usr/lib/system/libsystem_networkextension.dylib
0xa775e000 - 0xa7766ff3 libsystem_notify.dylib (172) <63E3CF8C-4F15-3D45-84A6-1218352031E9> /usr/lib/system/libsystem_notify.dylib
0xa7767000 - 0xa776dff3 libsystem_platform.dylib (161) <525A3EF0-E1ED-3EE2-A142-2149A43F9EBC> /usr/lib/system/libsystem_platform.dylib
0xa776e000 - 0xa7778ff7 libsystem_pthread.dylib (301.1.6) <7228A41C-AC5D-3612-B22E-374CB5433D1C> /usr/lib/system/libsystem_pthread.dylib
0xa7779000 - 0xa777cffb libsystem_sandbox.dylib (765.1.8) <79BFD3F5-0BC2-3DA6-A062-79CA966F779A> /usr/lib/system/libsystem_sandbox.dylib
0xa777d000 - 0xa777ffff libsystem_secinit.dylib (30) <CE2C90DE-27A4-3546-8A05-96B743861DD0> /usr/lib/system/libsystem_secinit.dylib
0xa7780000 - 0xa7788ff7 libsystem_symptoms.dylib (820.1.4) <131C3E51-0C07-38A4-9BDA-512D70BFBFD2> /usr/lib/system/libsystem_symptoms.dylib
0xa7789000 - 0xa779bfff libsystem_trace.dylib (829.1.2) <93044936-463B-3E35-9CDF-4B1B83896042> /usr/lib/system/libsystem_trace.dylib
0xa779d000 - 0xa77a3fff libunwind.dylib (35.3) <642BBA03-0411-3FAA-A421-D79A9156AB1C> /usr/lib/system/libunwind.dylib
0xa77a4000 - 0xa77ccff3 libxpc.dylib (1205.1.10) <D1C23A14-2F23-3858-9346-A35B47DFD92F> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2882926
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=283.8M resident=0K(0%) swapped_out_or_unallocated=283.8M(100%)
Writable regions: Total=155.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=155.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 2
Activity Tracing 256K 2
CG backing stores 4020K 4
CG image 1876K 6
CoreAnimation 36K 5
CoreGraphics 8K 2
CoreImage 16K 3
CoreServices 20K 2
CoreUI image file 188K 5
Foundation 4K 2
Kernel Alloc Once 8K 2
MALLOC 135.8M 43
MALLOC guard page 48K 13
Memory Tag 242 12K 2
OpenGL GLSL 128K 3
Stack 12.5M 11
Stack Guard 56.0M 11
VM_ALLOCATE 480K 21
__DATA 13.9M 242
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__IMPORT 4K 2
__LINKEDIT 78.1M 10
__OBJC 3800K 92
__TEXT 205.7M 246
__UNICODE 556K 2
mapped file 262.0M 208
shared memory 872K 15
TOTAL 778.8M 932
Model: MacBookPro13,3, BootROM MBP133.0233.B00, 4 processors, Intel Core i7, 2.7 GHz, 16 GB, SMC 2.38f7
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 455, AMD Radeon Pro 455, PCIe, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.37.0.1a1)
Bluetooth: Version 6.0.0f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.2
Version: 0.1
User ID: 501
Report Version: 12
VM Regions Near 0:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 9:
cr2: 0x00000000
Logical CPU: 0
Trap Number: 14
Binary Images:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
VIRTUAL REGION
CG image 1876K 6
CoreAnimation 36K 5
CoreGraphics 8K 2
CoreImage 16K 3
CoreServices 20K 2
Foundation 4K 2
MALLOC 135.8M 43
OpenGL GLSL 128K 3
Stack 12.5M 11
VM_ALLOCATE 480K 21
__DATA 13.9M 242
__FONT_DATA 4K 2
__IMPORT 4K 2
__LINKEDIT 78.1M 10
__OBJC 3800K 92
__TEXT 205.7M 246
__UNICODE 556K 2
TOTAL 778.8M 932
USB Device: iBridge
