High Sierra - crashes at starting [fixed]
Postby DJP13 » 03 November 2017, 01:32
Need your help. Showxpress is not opening for me, every time I try and open the program I get “TheLightingController quit unexpectedly”. I’ve uninstalled and reinstalled showxpress and restarted my computer. Can’t seem to get it to work. Do you know of a solution?
Running: macOS High Sierra Version 10.13
Showxpress version 8.2.24
Here is the problem details and system configuration:
Process: TheLightingController [24426]
Path: /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [24426]
User ID: 501
Date/Time: 2017-11-02 20:26:14.326 -0400
OS Version: Mac OS X 10.13 (17A405)
Report Version: 12
Bridge OS Version: 3.0 (14Y661)
Anonymous UUID: 0D3606D1-13DB-3607-7487-C1CAE4721CE7
Sleep/Wake UUID: E487386B-2A85-4FE3-BDF6-9D690BBAC848
Time Awake Since Boot: 97000 seconds
Time Since Wake: 98 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
__TEXT 0000000000001000-00000000001ec000 [ 1964K] r-x/rwx SM=COW G [/Volumes/ShowXpress_Mac 1/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 efk_usb.dylib 0x003f3573 CDeviceHandle::CDeviceHandle(unsigned int) + 501
1 efk_usb.dylib 0x003f2c5e CallbackHook(void*, unsigned int) + 78
2 efk_usb.dylib 0x003f2d11 usbCallbackConnect + 91
3 efk_hardware.dylib 0x05303c3c EFK_check_hardware + 744
Thread 1:
0 libsystem_kernel.dylib 0xa764471a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0xa77710a0 _pthread_wqthread + 1536
2 libsystem_pthread.dylib 0xa7770a7a start_wqthread + 34
Thread 2:
Thread 3:
1 libsystem_pthread.dylib 0xa7770e80 _pthread_wqthread + 992
Thread 4:
1 libsystem_pthread.dylib 0xa7770eab _pthread_wqthread + 1035
Thread 5:
Thread 6:
Thread 7:
Thread 8:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0xa763ad22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0xa763a35f mach_msg + 47
2 com.apple.CoreFoundation 0x939016e8 __CFRunLoopServiceMachPort + 296
3 com.apple.CoreFoundation 0x939006d6 __CFRunLoopRun + 2262
4 com.apple.CoreFoundation 0x938ffad1 CFRunLoopRunSpecific + 641
5 com.apple.CoreFoundation 0x938ff83a CFRunLoopRunInMode + 122
6 com.apple.AppKit 0x91489095 _NSEventThread + 165
7 libsystem_pthread.dylib 0xa777151d _pthread_body + 347
8 libsystem_pthread.dylib 0xa77713c2 _pthread_start + 357
9 libsystem_pthread.dylib 0xa7770a9e thread_start + 34
Thread 9:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x003f3389 ecx: 0xa9a801f0 edx: 0x00012068
edi: 0x00514120 esi: 0x00514e80 ebp: 0xbffffa78 esp: 0xbffff9d0
ss: 0x00000023 efl: 0x00010282 eip: 0x003f3573 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x1ebff7 +TheLightingController (0.1) <9578A96A-6AA3-3DE8-A304-8C5EDD09322D> /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x365000 - 0x3aafcf dyld (519.2.1) <3FEC6B17-882D-32AA-9D24-CBD9B1FD18EA> /usr/lib/dyld
0x3f1000 - 0x3f3fff +efk_usb.dylib (1) <204D39A5-A168-521D-2EFF-8DD8DE656AC5> /Volumes/*/efk_usb.dylib
0x5300000 - 0x5320ffb +efk_hardware.dylib (0) <0F1950F0-6926-38D5-B52B-D947A63D1BED> /Volumes/*/efk_hardware.dylib
0x9099000 - 0x90a1ff7 com.apple.iokit.IOUSBLib (900.4.1 - 900.4.1) <E0935891-8DB3-3111-AC39-0B780DAA8C56> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x9200000 - 0x92c7fff com.apple.AMDRadeonX4000GLDriver (1.58.30 - 1.5.8) <5051E160-6126-324F-A8F5-2771B8BE4E3F> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0xa000000 - 0xaca3fff com.apple.driver.AppleIntelSKLGraphicsGLDriver (10.28.26 - 10.2.8) <03E45C76-1B10-326A-A2E2-AEECEFE55903> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
0xafce000 - 0xb6fcfff ATIRadeonX4000SCLib.dylib (1.58.30) <308197C7-1136-375C-819E-CB6C6BBC799C> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x9001d000 - 0x901d3ff3 com.apple.avfoundation (2.0 - 1334) <8D7020E4-09A5-3E52-AA0E-D6607F336791> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x901d4000 - 0x9028effb com.apple.audio.AVFAudio (1.0 - ???) <DE391193-A166-3916-8A14-7DBE68BC7ACA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x90290000 - 0x90290fff com.apple.Accelerate (1.11 - Accelerate 1.11) <65375A38-816E-3360-ADF5-F1D466EAE43B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90291000 - 0x902a7ffb libCGInterfaces.dylib (417) <92B03F58-1974-35E7-BC7F-28B6B285A860> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x902a8000 - 0x909e9fdf com.apple.vImage (8.1 - ???) <591C941E-6475-347E-89DA-F541E88F949A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x909ea000 - 0x90b25ff7 libBLAS.dylib (1211) <ECA7DF28-62AA-3A71-9D82-DB3A14553E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x90b26000 - 0x90b53ff7 libBNNS.dylib (32) <8761FEAA-6846-31F1-80AC-54315D61395F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x90b54000 - 0x90ec7fff libLAPACK.dylib (1211) <8B0949D5-035C-3216-9D15-17BA099DBF58> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90ec8000 - 0x90edeffb libLinearAlgebra.dylib (1211) <6ADA0BFE-3AAF-3430-8BD8-8C604EBEA81A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x90edf000 - 0x90ef8ff7 libSparseBLAS.dylib (1211) <0C7848B1-0F3B-3EB7-8784-57D15012D2B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x90ef9000 - 0x9104bfef libvDSP.dylib (622) <9C75C687-597F-38D3-8736-73D9F94A6430> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9104c000 - 0x9112aff7 libvMisc.dylib (622) <586BE48F-78E9-3EA7-9837-6B4F926613B1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9112b000 - 0x9112bfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D750F2CC-FDBC-3486-8BAD-6B828D4814BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9131a000 - 0x920daff7 com.apple.AppKit (6.9 - 1561.0.100) <F6F4335C-8380-3220-98FF-55822AE7D0D6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9212c000 - 0x9212cfff com.apple.ApplicationServices (48 - 50) <7557388A-2C5B-3467-8793-D56E4B57A1FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9212d000 - 0x92193ff3 com.apple.ApplicationServices.ATS (377 - 445) <1C8196A6-CF4F-3E08-B067-61B870F72DA3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92196000 - 0x922baff3 libFontParser.dylib (222.1) <EF22371D-9F4F-3F8F-8935-748B5360F69C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x922bb000 - 0x92307ffb libFontRegistry.dylib (221) <8D81FDCF-F05D-3556-AB6D-090F9508C25E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92356000 - 0x92389fff libTrueTypeScaler.dylib (222.1) <486F15D0-6314-3730-82AD-CB338560C506> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x923f5000 - 0x923fafff com.apple.ColorSyncLegacy (4.13.0 - 1) <2210061E-63BC-3B26-B8AE-560DC457F127> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x924a4000 - 0x924fbff7 com.apple.HIServices (1.22 - 622) <8544026A-17BE-301D-BA2A-782F3AD864DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x924fc000 - 0x9250bff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <E3245701-039B-353F-923D-F81B2242842C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9250c000 - 0x92564ffb com.apple.print.framework.PrintCore (13 - 503) <FCCA7283-94EC-3D6C-B962-6B4CDD50D9A7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92565000 - 0x925fbffb com.apple.QD (3.12 - 403) <372AFF26-17D1-3C6F-9E47-17C955C2045B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x925fc000 - 0x92608ff3 com.apple.speech.synthesis.framework (7.0.14 - 7.0.14) <F0AAFDF5-3254-3F8B-9575-6F972A179131> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92609000 - 0x92853ffb com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <3D8460F9-6192-3983-83F8-7D2AE16D2DA1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92855000 - 0x92855fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <146E2F6D-A64B-3AC4-99C0-857700540696> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92b74000 - 0x92eb3ff7 com.apple.CFNetwork (887 - 887) <379FD334-1AF6-3FA4-8B7C-890995AEC4F0> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92ec8000 - 0x92ec8fff com.apple.Carbon (158 - 158) <83C4D410-E216-3EAC-A663-94645F4BCB86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92ec9000 - 0x92ed2ff3 com.apple.audio.SoundManager (4.2 - 4.2) <83AE7AA9-8661-3449-99F4-291A42640692> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92ed3000 - 0x92ed7fff com.apple.CommonPanels (1.2.6 - 98) <DA1D99A4-53F6-31AF-964D-86739FA74B52> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92ed8000 - 0x9326dff7 com.apple.HIToolbox (2.1.1 - 909.1) <2AF1ACB9-424B-38FD-B15C-06AB6D2BAF4F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9326e000 - 0x932c2ffb com.apple.htmlrendering (77 - 1.1.4) <BAF5C846-FF50-3C80-97F5-71F1399CA85C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x932c3000 - 0x932c6fff com.apple.help (1.3.8 - 64) <1E913488-5D7B-388E-904D-64EF8C99E704> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x932c7000 - 0x932ccffb com.apple.ImageCapture (9.0 - 9.0) <1887749B-D641-3057-B91F-3C2D8E990115> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x932cd000 - 0x93367ffb com.apple.ink.framework (10.9 - 220) <5340E055-BD3D-35AD-9797-F22E1ECEDAC6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93368000 - 0x933a2fff com.apple.NavigationServices (3.8 - 227) <6B1000C3-9C00-33F5-88D5-62F6BD5DD7F8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x933a3000 - 0x933beffb com.apple.openscripting (1.7 - 174) <DFBC4482-0915-3C4F-8C9A-7A7A1620C3B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x933bf000 - 0x933c4fff com.apple.print.framework.Print (12 - 267) <F7BEF8BA-7D1F-34A2-97B8-D49F20886644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x933c5000 - 0x933c7fff com.apple.securityhi (9.0 - 55006) <E9FF8254-B8E1-312A-8FC3-2B4EA8CE9AEA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x933c8000 - 0x933cefff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C27FB7B-A467-3171-A73B-8C9B403028E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x933cf000 - 0x933cffff com.apple.Cocoa (6.11 - 22) <83D0A833-FD91-364B-AA4C-B5FCEB7F66BF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x933dc000 - 0x9349bff7 com.apple.ColorSync (4.13.0 - 544) <AA55BFD7-A5AD-35AC-B64B-93A798EBED1D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9349c000 - 0x93537fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <9D1B217E-03F6-38F6-B737-DE5D5DC6DA15> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93595000 - 0x9359afff com.apple.CoreBluetooth (1.0 - 1) <E0F40A70-9E04-31FE-A4C8-BE05F6432BAD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x9359b000 - 0x9387afff com.apple.CoreData (120 - 847.1) <2AC013DC-8148-34C9-89B1-41353CAECD7F> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9387b000 - 0x93881ff3 com.apple.CoreDisplay (1.0 - 79.7) <98FDF833-62E9-38D3-8155-40A184276A61> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x93882000 - 0x93d0aff7 com.apple.CoreFoundation (6.9 - 1443.13) <31DD4E52-D928-3CF8-BA35-B0080DDBC424> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93d0c000 - 0x9433affb com.apple.CoreGraphics (2.0 - 1125.1.1) <4F472247-7953-3DD7-88A4-8DB0065ECC0C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9433c000 - 0x945c1ffb com.apple.CoreImage (13.0.0 - 573) <6D197299-898E-3BAD-ABB6-444800945B50> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x94633000 - 0x94679fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <545850CB-096A-37E3-8FDB-0640B5D222E6> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x9467c000 - 0x94758ff7 com.apple.CoreMedia (1.0 - 2074.3) <9FBB254B-E142-37EB-98C5-0E851FC5D431> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x94759000 - 0x947abfff com.apple.CoreMediaIO (803.0 - 4976) <A51DE163-E26A-3186-AB73-07B7181D8AF0> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x947ac000 - 0x947acfff com.apple.CoreServices (822.9 - 822.9) <717212C8-310C-3DDF-8CC9-F0BC46A25225> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x947ad000 - 0x9481ffff com.apple.AE (733 - 733) <C981EE72-993D-3E0A-AB53-47ABB7C57EE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94820000 - 0x94afeffb com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <E61EA71D-294F-3C8B-95BD-0CDBA0FFC907> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94aff000 - 0x94b33ff3 com.apple.DictionaryServices (1.2 - 284) <56BEF6B8-50D2-38A0-9EF2-D7093E9AAB56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94b34000 - 0x94b3cfff com.apple.CoreServices.FSEvents (1239 - 1239) <CABC21F7-E3AB-3954-ACBE-B8066A37516A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x94b3d000 - 0x94c9aff7 com.apple.LaunchServices (822.9 - 822.9) <76540FA9-7B3C-3747-BC45-FF2809B479A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94c9b000 - 0x94d47ff7 com.apple.Metadata (10.7.0 - 1191) <A1BA6522-F4E3-31AD-8E3D-64A26F2B6200> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94d48000 - 0x94da6ff3 com.apple.CoreServices.OSServices (822.9 - 822.9) <463DB8DD-1A42-33AC-B12F-2A2C982F0C6A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x94da7000 - 0x94e18ff3 com.apple.SearchKit (1.4.0 - 1.4.0) <FAD60011-970B-3889-B6BD-3715CCF599CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94e19000 - 0x94e3cfff com.apple.coreservices.SharedFileList (71.2 - 71.2) <7384B131-3CCF-3F40-8BE4-090B05C3D38A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x94e3d000 - 0x94f87ff7 com.apple.CoreText (352.0 - 578.3) <8165D2A6-0A1B-3DE7-81B6-F9DCCE480BA6> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x94f88000 - 0x94fc2ff3 com.apple.CoreVideo (1.8 - 278.0) <D6EF38C6-9ECF-3DDC-BAE5-BA8FFA63A2CB> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94fc3000 - 0x95049ff3 com.apple.framework.CoreWLAN (13.0 - 1335) <54FE3AB9-A361-3D5D-AC9F-9C654AFDECAB> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x9529d000 - 0x952a6ff7 com.apple.DiskArbitration (2.7 - 2.7) <E3552A79-57A4-36AE-8B54-5FE2EB5193DA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x952b7000 - 0x95624ff7 com.apple.Foundation (6.9 - 1443.14) <2D74E68D-2034-309B-B8B0-E7975A52BA23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95665000 - 0x95694fff com.apple.GSS (4.0 - 2.0) <09F9AD7C-8FD8-3660-9AD4-C6610689682B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x956c0000 - 0x957d7ff7 com.apple.Bluetooth (6.0.0 - 6.0.0f7) <1005CBBF-C447-33C8-BC90-0E85A1BC0536> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x9583f000 - 0x958dfffb com.apple.framework.IOKit (2.0.2 - 1445.1.3) <7D7DD393-BCA5-3E91-8F97-5968CBFC7D3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x958e1000 - 0x958e7fff com.apple.IOSurface (209 - 209) <CEB65557-BBAB-3233-ABCB-2AE4104DD876> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9593b000 - 0x95ab8fff com.apple.ImageIO.framework (3.3.0 - 1694) <58E20069-1F71-3D8C-98EC-7B68BDCFDECD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95ab9000 - 0x95abdffb libGIF.dylib (1694) <39E7C8B4-47DC-3894-87C6-860EA24E243C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95abe000 - 0x95baffff libJP2.dylib (1694) <184F41CE-3897-3F7C-8666-F77829CA9677> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95bb0000 - 0x95bd2ff7 libJPEG.dylib (1694) <CA457944-109E-35B5-B558-011724EC63DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95eb3000 - 0x95ed9ff7 libPng.dylib (1694) <60381815-963F-31FB-9947-0B677E6C8D78> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95eda000 - 0x95edcffb libRadiance.dylib (1694) <620092C3-DB38-3962-967E-34F65C3EE97B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95edd000 - 0x95f27ff3 libTIFF.dylib (1694) <A5E2A4FB-BEE4-3D4E-B80E-5342B6BC02D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95fd5000 - 0x96803ff7 com.apple.JavaScriptCore (13604 - 13604.1.38.1.6) <9D384BD6-E3B9-3D40-8FD3-D72AC358FB8F> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9681b000 - 0x96833fff com.apple.Kerberos (3.0 - 1) <8A399DB7-5440-3EC0-A241-3DD10E82DDB2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9688b000 - 0x96893fff com.apple.MediaAccessibility (1.0 - 114) <087BD9A6-6E5E-3884-B4F7-8F0A6B662B8D> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x96894000 - 0x96e89ffb com.apple.MediaToolbox (1.0 - 2074.3) <D9CFE9AF-DFC9-3175-BBE4-5A9CA618176F> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x96e8b000 - 0x96f01ff7 com.apple.Metal (123.3.5 - 123.3.5) <9F8F2C16-236A-39CA-A11F-8D762DB4E37C> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x96f03000 - 0x96f0ffff com.apple.NetFS (6.0 - 4.0) <F37A4DA0-AAB6-3F0B-BA18-E322BFA52CC4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x99c43000 - 0x99c4bff7 libcldcpuengine.dylib (2.8.7) <E3B50B98-E1E4-396C-BB05-935AACC6FD80> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x99c4c000 - 0x99c97fff com.apple.opencl (2.8.11 - 2.8.11) <A91D3A7A-EACD-3F44-897C-C6DB723CEC03> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x99c98000 - 0x99cb4fff com.apple.CFOpenDirectory (10.13 - 207) <703506C0-FE72-36F3-990A-76A72064B3B9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x99cb5000 - 0x99cc0fff com.apple.OpenDirectory (10.13 - 207) <F5BED4FF-26F2-3580-93ED-4F6B27D99E2F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9aeca000 - 0x9aecbfff libCVMSPluginSupport.dylib (16.0.3) <421F979D-C793-32E1-B84E-09AAA2F0EE44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9aecc000 - 0x9aecffff libCoreFSCache.dylib (160.9) <A16ACDE7-22D4-362D-98A8-023F3D61989C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x9aed0000 - 0x9aed4fff libCoreVMClient.dylib (160.9) <B8BD8FDA-0A77-3668-AA68-ADE5910BAB14> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9aed5000 - 0x9aeddff7 libGFXShared.dylib (16.0.3) <8448CB42-18AE-3279-B11B-ECD74AA1ECC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9aede000 - 0x9aeeafff libGL.dylib (16.0.3) <B10792CA-814B-3E00-9D1A-626C2CBCEEC7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9aeeb000 - 0x9af26ffb libGLImage.dylib (16.0.3) <A071BC79-94CE-3075-8139-154A576AFAA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9af27000 - 0x9b09fffb libGLProgrammability.dylib (16.0.3) <D5B975A4-D735-3ECD-BE1D-8FF351C37F49> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9b0a0000 - 0x9b0e2ff7 libGLU.dylib (16.0.3) <2614C4B3-A4D2-39CA-9480-46E376546391> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9ba89000 - 0x9ba97fff com.apple.opengl (16.0.3 - 16.0.3) <CCA4EA13-DBF6-314D-A6AE-0C273393B425> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9ba98000 - 0x9bc25ffb GLEngine (16.0.3) <89092021-3FE7-300B-AFFF-033408721599> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x9bc26000 - 0x9bc50fff GLRendererFloat (16.0.3) <76940B7B-2617-3789-A277-2B30389E7A51> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x9bd6e000 - 0x9bebfffb com.apple.QTKit (7.7.3 - 3014) <9DB2668A-3F68-32F0-BF51-C7F791FEE8EE> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9c806000 - 0x9ca37fff com.apple.QuartzCore (1.11 - 574.1.4) <22685244-B08A-3BA4-83EB-7097E0AAA52B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9ca8d000 - 0x9cce5feb com.apple.QuickTime (7.7.3 - 3014) <A38CF029-378C-3D67-9359-7DC15452B0E4> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9cecd000 - 0x9d200ff3 com.apple.security (7.0 - 58286.1.33) <97C1F7D1-10BD-3A08-98DF-258892DF64CF> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9d201000 - 0x9d287ff3 com.apple.securityfoundation (6.0 - 55185.1.1) <0CAAFA4B-8779-3927-AB0F-DA6BA8AF12EF> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9d2b0000 - 0x9d2b4fff com.apple.xpc.ServiceManagement (1.0 - 1) <C830416D-0D84-303D-A2BD-1A186B193DF9> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x9d3dd000 - 0x9d44dffb com.apple.SystemConfiguration (1.17 - 1.17) <C03891C9-927C-3433-BB6E-9103D7A37D06> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9d5f7000 - 0x9d982fff com.apple.VideoToolbox (1.0 - 2074.3) <D4FEC64B-7282-3655-93EC-850BB5B5885A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x9d983000 - 0x9ed2fffb com.apple.WebCore (13604 - 13604.1.38.1.6) <0FC2DF17-1806-39F8-ABCD-A74EFF243524> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9ed30000 - 0x9eec2ffb com.apple.WebKitLegacy (13604 - 13604.1.38.1.6) <40828462-3F33-3D4D-B2FE-0C8BAB45F99A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x9eec3000 - 0x9f1feff7 com.apple.WebKit (13604 - 13604.1.38.1.6) <F24FDE02-8F4B-3F30-97EB-8DF0E90E6EAA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9f210000 - 0x9f2a4ff7 com.apple.APFS (1.0 - 1) <6AE092B7-C6A3-3B08-83CA-531CF4842EBE> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x9f88f000 - 0x9f8baff3 com.apple.framework.Apple80211 (13.0 - 1335) <729DBF0C-4F9E-3DA3-8883-4E8FB59D7560> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9f8bc000 - 0x9f8c6fff com.apple.AppleFSCompression (96.1.1 - 1.0) <38FA63FB-6E9E-3382-80E2-111F42CB1EE3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x9f9bd000 - 0x9f9fafff com.apple.AppleJPEG (1.0 - 1) <A79335BD-B17F-3340-B5AD-2230B83878C0> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9faf4000 - 0x9fb43ffb com.apple.AppleVAFramework (5.0.39 - 5.0.39) <89895B3A-FA16-35EC-9A2C-22AF1A311A1D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9fb4d000 - 0x9fb54fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <3CEE4D97-2EAB-3400-A31D-92D2E3D8088C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x9fb55000 - 0x9fbe0ffb com.apple.backup.framework (1.9 - 1.9) <C71A70C4-F474-363C-BD15-383C5BC311CA> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9fd23000 - 0x9fd2cfff com.apple.CommonAuth (4.0 - 2.0) <17A264D0-9611-33EA-9081-6CA2E277655C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9fdd5000 - 0xa00edfef com.apple.CoreAUC (249.0.0 - 249.0.0) <77A27B7D-9EB4-39E0-9411-C9B7BDF0B1A8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0xa00ee000 - 0xa011ffff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <EC1E91A7-CFD3-31E4-AE53-1D57BC7F852A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0xa019d000 - 0xa01adfff com.apple.CoreEmoji (1.0 - 69) <1183DFFF-DC0E-33CF-A261-0E0308CE5FDC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0xa01ae000 - 0xa01c4ff7 com.apple.CoreMediaAuthoring (2.2 - 956) <7FB86A4B-5DC0-3267-AC40-3A99436D3FF1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0xa032b000 - 0xa035eff7 com.apple.CoreServicesInternal (309 - 309) <C26C43BC-891C-3A34-8DDC-6C5356BB56CE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0xa035f000 - 0xa03f5ff3 com.apple.CoreSymbolication (63075) <82E57290-F924-321F-97A4-E158434B4A19> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0xa03f6000 - 0xa051cfeb com.apple.coreui (2.1 - 489) <D162F5FC-E903-36EF-B10C-9CA674F543A1> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0xa051d000 - 0xa05b7fff com.apple.CoreUtils (5.2 - 520.68) <86913493-85C4-380B-82FF-81D160E1FE1F> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0xa0608000 - 0xa0665ff3 com.apple.framework.CoreWiFi (13.0 - 1335) <6EFABB25-6759-34B1-98CD-87421E393A86> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0xa0666000 - 0xa0676fff com.apple.CrashReporterSupport (10.13 - 1) <D65CA840-BAD7-3D1E-A245-C8F3E5320DEA> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0xa06e4000 - 0xa06f1fff com.apple.framework.DFRFoundation (1.0 - 189.1) <53CE2E61-9ECE-339E-94E7-3E428A9142B4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0xa073e000 - 0xa07aefff com.apple.datadetectorscore (7.0 - 590) <9634322F-D458-3964-8A01-CE39FD33D64C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0xa07af000 - 0xa07efffb com.apple.DebugSymbols (141 - 141) <96BB879B-1A83-3622-BB02-1DDA5C4FD939> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0xa07f0000 - 0xa0928ff3 com.apple.desktopservices (1.12 - 1.12) <FB7D558C-0C67-304B-9778-35CA9624EB02> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0xa0bf3000 - 0xa1023ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <B2288C3D-E67F-3AAE-A652-E920CD19F267> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0xa2dcd000 - 0xa2dd7fff libGPUSupportMercury.dylib (16.0.3) <C17E1EC3-4DAB-3F2B-B999-D6461CBB04F4> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0xa39bd000 - 0xa3a30ff3 com.apple.Heimdal (4.0 - 2.0) <2A215F01-C54B-3386-A731-2C92B26B50E6> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0xa3cdf000 - 0xa3ce5fff com.apple.IOAccelerator (373 - 373) <C3D082C6-4EDC-35F4-A1EF-FA9C837B330B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0xa3ce6000 - 0xa3cfefff com.apple.IOPresentment (1.0 - 32.1) <808BF662-E235-31F1-95C6-D8657A259BA3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0xa3d5b000 - 0xa3d7aff3 com.apple.IconServices (97.3 - 97.3) <B8BBEF67-8A6A-3F6D-A859-4E893CF3262F> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0xa3d83000 - 0xa3d92fff com.apple.IntlPreferences (2.0 - 227) <530C7334-9F93-322A-9F4B-E449922F2498> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0xa3db2000 - 0xa3ea6fff com.apple.LanguageModeling (1.0 - 159) <72552B38-94F9-3579-BCA6-FA67599D7FC5> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0xa3ea7000 - 0xa3ee8ff3 com.apple.Lexicon-framework (1.0 - 33) <68E2818A-D287-3765-BD97-751D40D82697> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0xa3eec000 - 0xa3ef2ffb com.apple.LinguisticData (1.0 - 238) <DADD1591-7608-3B63-951B-9BA8931BDE60> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0xa429e000 - 0xa42c7ffb com.apple.MultitouchSupport.framework (1004.1 - 1004.1) <ABA83552-FA26-31D3-9C32-5C7D24157ADF> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0xa43e6000 - 0xa43f0fff com.apple.NetAuth (6.2 - 6.2) <52F67DC1-8C96-3944-8E54-C02DD51FD9FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0xa4498000 - 0xa44d4fff com.apple.PerformanceAnalysis (1.183 - 183) <52CA4DBF-4C1D-3D30-8FD4-EF595C1B6C71> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0xa4572000 - 0xa458eff7 com.apple.ProtocolBuffer (1 - 259) <BBB59E09-0B06-3262-9C81-C126DF34667C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0xa467a000 - 0xa469cfff com.apple.RemoteViewServices (2.0 - 125) <5720B413-E761-3368-964F-7FEAC5535669> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0xa4752000 - 0xa477effb com.apple.Sharing (910.7 - 910.7) <F232ED72-400D-35E4-8089-FAF1036E6FEB> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0xa479d000 - 0xa479efff com.apple.performance.SignpostNotification (1.0 - 1) <5B9FAEF5-EB02-3B2A-AC6E-1E80AA59A7F1> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0xa479f000 - 0xa4824ff3 com.apple.SkyLight (1.600.0 - 312) <0F1157F0-97A0-3527-B177-4A2B9F925C67> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0xa4854000 - 0xa4861ffb com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <BACA23B0-AF15-3B7F-8933-15DDEE48318B> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0xa4b2e000 - 0xa4bafff3 com.apple.Symbolication (9.0 - 63079.1) <97DA4973-352E-3CBA-9B4A-BC22C3AFD597> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0xa4c02000 - 0xa4c09fff com.apple.TCC (1.0 - 1) <8E4DD699-FE42-3B8E-AE2D-FB9AD29C927B> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0xa4c0a000 - 0xa4c21ff3 com.apple.TextureIO (3.4 - 3.4) <5C14EC48-1C46-39E3-ACB5-ADA3F7E2BFA8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0xa4c48000 - 0xa4c49fff com.apple.TrustEvaluationAgent (2.0 - 31) <185BD5A9-5A2D-3317-B7FE-9B67F14C4D2C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0xa4c4a000 - 0xa4dd4fff com.apple.UIFoundation (1.0 - 543) <2B11011C-CECA-309F-8D02-6DA6B38AA6FD> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0xa53a2000 - 0xa53a4fff com.apple.loginsupport (1.0 - 1) <086FAE1B-87E2-324A-AE76-E6EC0B5F1517> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0xa542f000 - 0xa5462ff7 libclosured.dylib (519.2.1) <1C4AD77C-926A-3BD9-B8A2-81BC766497C9> /usr/lib/closure/libclosured.dylib
0xa54b2000 - 0xa54e9ff3 libCRFSuite.dylib (41) <7F584902-74F1-3362-935D-95F5E735F5E7> /usr/lib/libCRFSuite.dylib
0xa54ea000 - 0xa54f4ffb libChineseTokenizer.dylib (28) <1FF5A32D-E012-3E76-B738-FAC26AD2A39B> /usr/lib/libChineseTokenizer.dylib
0xa5590000 - 0xa5591fff libDiagnosticMessagesClient.dylib (104) <6829B180-2556-3A7E-A2E6-BD4859DF30A7> /usr/lib/libDiagnosticMessagesClient.dylib
0xa55c3000 - 0xa57adff7 libFosl_dynamic.dylib (17.7) <DBE4D720-8A46-3879-AD2D-F9A8CE3E7476> /usr/lib/libFosl_dynamic.dylib
0xa57b5000 - 0xa57b5fff libOpenScriptingUtil.dylib (174) <B7CEDC30-2D17-3896-9EFC-64DB3D11DF00> /usr/lib/libOpenScriptingUtil.dylib
0xa57fe000 - 0xa5802fff libScreenReader.dylib (562.1) <A2A66CC0-780C-3751-AC41-075118B8EF14> /usr/lib/libScreenReader.dylib
0xa5803000 - 0xa5804fff libSystem.B.dylib (1252) <96309D00-55F1-36DB-9A6B-94DE5E7167E4> /usr/lib/libSystem.B.dylib
0xa5813000 - 0xa5828ff7 libapple_nghttp2.dylib (1.24) <480C0C04-2533-3D44-8232-006B6CBA7758> /usr/lib/libapple_nghttp2.dylib
0xa5829000 - 0xa5854fff libarchive.2.dylib (54) <D55C5F86-251D-3C33-A617-0C623D4F512E> /usr/lib/libarchive.2.dylib
0xa5855000 - 0xa59a4ffb libate.dylib (1.13.1) <E109CCBF-357D-3C87-9CE5-D53AE03609A2> /usr/lib/libate.dylib
0xa59a8000 - 0xa59a8ff3 libauto.dylib (187) <CE2A78CC-670F-3E07-9539-822DCD2F6084> /usr/lib/libauto.dylib
0xa59a9000 - 0xa59b9fff libbsm.0.dylib (39) <067E9003-0673-32A3-9B40-492323182C5C> /usr/lib/libbsm.0.dylib
0xa59ba000 - 0xa59c6ff7 libbz2.1.0.dylib (38) <77C24A36-BE84-3702-A786-935C597A0A86> /usr/lib/libbz2.1.0.dylib
0xa59c7000 - 0xa5a20ffb libc++.1.dylib (400.9) <AD612EEF-6CE3-315D-82C2-58248BE13431> /usr/lib/libc++.1.dylib
0xa5a21000 - 0xa5a42fff libc++abi.dylib (400.7) <41323E53-C7EA-3E9A-BD30-38E82399F843> /usr/lib/libc++abi.dylib
0xa5a44000 - 0xa5a55ff7 libcmph.dylib (6) <EC7664F1-B5A1-37F4-B7DC-F6AC10587E35> /usr/lib/libcmph.dylib
0xa5a56000 - 0xa5a69ff7 libcompression.dylib (47) <F80DDFC1-F96A-3BAD-967D-C1E24253273A> /usr/lib/libcompression.dylib
0xa5a6a000 - 0xa5a81ffb libcoretls.dylib (155) <F66FAEBC-4B6E-31E0-ACA8-C8ACBC7689DD> /usr/lib/libcoretls.dylib
0xa5a82000 - 0xa5a83fff libcoretls_cfhelpers.dylib (155) <8B8ABC2C-F251-3C80-9747-88C05A2CBE64> /usr/lib/libcoretls_cfhelpers.dylib
0xa5c04000 - 0xa5dabfff libcrypto.35.dylib (22) <EE1BA2F7-F2F4-387B-8866-5B4A7023D29F> /usr/lib/libcrypto.35.dylib
0xa5f6b000 - 0xa5fc2fff libcups.2.dylib (462) <0EF67F4A-8E0A-3349-9259-5AC3D65143D6> /usr/lib/libcups.2.dylib
0xa60d8000 - 0xa60d8fff libenergytrace.dylib (16) <34FC43C7-D9B6-3C01-8B65-E49059D31279> /usr/lib/libenergytrace.dylib
0xa60d9000 - 0xa60f0ffb libexpat.1.dylib (16.1.1) <3E73B1C8-216F-3E94-83AE-59559365D2DD> /usr/lib/libexpat.1.dylib
0xa610c000 - 0xa6110fff libheimdal-asn1.dylib (520) <506DE95C-3CB0-33ED-9DC0-B5D4665BE010> /usr/lib/libheimdal-asn1.dylib
0xa613c000 - 0xa622cff3 libiconv.2.dylib (51) <FE6D05A5-18DB-3FD8-A52F-B7BADB232C78> /usr/lib/libiconv.2.dylib
0xa622d000 - 0xa644fffb libicucore.A.dylib (59117.0.1) <8D56A4D5-C688-36AE-853E-875C09164234> /usr/lib/libicucore.A.dylib
0xa6497000 - 0xa6498fff liblangid.dylib (128) <120FE992-47E4-3A73-A039-1B401F5696DC> /usr/lib/liblangid.dylib
0xa6499000 - 0xa64b1ff7 liblzma.5.dylib (10) <8A5C9679-430A-3A19-AF68-9D21BAC442C7> /usr/lib/liblzma.5.dylib
0xa64b2000 - 0xa64c7fff libmarisa.dylib (9) <805453EE-B829-3DA5-8DF3-5132D03D5B74> /usr/lib/libmarisa.dylib
0xa657c000 - 0xa6798fff libmecabra.dylib (779.1) <07D38CF9-A4A2-35D1-A996-E7F29BD561E1> /usr/lib/libmecabra.dylib
0xa695f000 - 0xa6a32ff3 libnetwork.dylib (1229.1.5) <A9164BB1-E070-3D48-96A4-E77BB351B18A> /usr/lib/libnetwork.dylib
0xa6a33000 - 0xa6e130fb libobjc.A.dylib (723) <4AF346B8-C1A8-3199-B1BB-ADEDD64D5C1A> /usr/lib/libobjc.A.dylib
0xa6e17000 - 0xa6e1afff libpam.2.dylib (22) <7106F43C-84DD-3F26-905A-B52780AFEB3E> /usr/lib/libpam.2.dylib
0xa6e1d000 - 0xa6e4efff libpcap.A.dylib (79) <178094CE-BF5A-3C92-9A74-525AA907FA21> /usr/lib/libpcap.A.dylib
0xa6e8c000 - 0xa6ea7ffb libresolv.9.dylib (65) <65A43F5B-CF88-3948-AE5C-D7CA02D814A1> /usr/lib/libresolv.9.dylib
0xa6ef2000 - 0xa707ffff libsqlite3.dylib (274.1) <6EDB0451-67F8-3870-8EF9-50346FC26669> /usr/lib/libsqlite3.dylib
0xa718f000 - 0xa71dfffb libstdc++.6.0.9.dylib (104.1) <74744B76-524A-3052-A4CF-3C47446A32C0> /usr/lib/libstdc++.6.0.9.dylib
0xa7223000 - 0xa725dffb libusrtcp.dylib (1229.1.5) <28CC4C32-DAFF-3C05-A288-97EA513DC10D> /usr/lib/libusrtcp.dylib
0xa725e000 - 0xa7261fff libutil.dylib (51) <C041EF3C-8E30-3F43-BCE2-7DA3E3673A8A> /usr/lib/libutil.dylib
0xa7262000 - 0xa7270ff7 libxar.1.dylib (400) <4B664A7E-EC05-34AD-ACC6-C879B69DBA7C> /usr/lib/libxar.1.dylib
0xa7271000 - 0xa734fff7 libxml2.2.dylib (31.7) <3E1F9E3D-6C44-3437-AB2B-E5ACE1927F81> /usr/lib/libxml2.2.dylib
0xa7350000 - 0xa7378ff3 libxslt.1.dylib (15.10) <1A3DC7B8-7C92-3D73-BF82-D60E64BC3DF0> /usr/lib/libxslt.1.dylib
0xa7379000 - 0xa7388ff7 libz.1.dylib (70) <588F445F-0065-3D77-8002-BA9411DA1D70> /usr/lib/libz.1.dylib
0xa73c1000 - 0xa73c5fff libcache.dylib (80) <5D011637-CADA-38A1-A695-CE049657FD9D> /usr/lib/system/libcache.dylib
0xa73c6000 - 0xa73d0fff libcommonCrypto.dylib (60118.1.1) <536D7954-7C70-368F-BF63-A02A4E4529D6> /usr/lib/system/libcommonCrypto.dylib
0xa73d1000 - 0xa73d6fff libcompiler_rt.dylib (62) <FA07FEE2-CEFE-3CC0-A82F-E601AA2CCB36> /usr/lib/system/libcompiler_rt.dylib
0xa73d7000 - 0xa73e0ff7 libcopyfile.dylib (146) <13E84219-DA7C-3774-BB84-56CB93C8C8BB> /usr/lib/system/libcopyfile.dylib
0xa73e1000 - 0xa7448fff libcorecrypto.dylib (562) <FF27DFD5-EEF0-3045-87D0-28F746007FB2> /usr/lib/system/libcorecrypto.dylib
0xa74b2000 - 0xa74e7ffb libdispatch.dylib (913.1.6) <6C6E14A6-E999-3E7B-AD06-A258FC5B2ED1> /usr/lib/system/libdispatch.dylib
0xa74e8000 - 0xa7505fff libdyld.dylib (519.2.1) <85A28A4C-AFE5-3A7E-A16D-10C304A86040> /usr/lib/system/libdyld.dylib
0xa7506000 - 0xa7506fff libkeymgr.dylib (28) <C448ACFC-DD1B-3F08-B4C3-D2B69D1210B1> /usr/lib/system/libkeymgr.dylib
0xa7507000 - 0xa7513ff7 libkxld.dylib (4570.1.46) <6C86E320-D9FE-3DE1-8EAE-88D0115FCD84> /usr/lib/system/libkxld.dylib
0xa7514000 - 0xa7514fff liblaunch.dylib (1205.1.10) <4C5BA334-9EA5-3EFA-8C2D-BD4A234978E4> /usr/lib/system/liblaunch.dylib
0xa7515000 - 0xa751afff libmacho.dylib (900.0.1) <F1F0BC1D-A2D9-39F9-9A11-263F8392CB3B> /usr/lib/system/libmacho.dylib
0xa751b000 - 0xa751dfff libquarantine.dylib (86) <68DE2EB2-7911-304D-89D6-1517CA689001> /usr/lib/system/libquarantine.dylib
0xa751e000 - 0xa751ffff libremovefile.dylib (45) <BEF76B44-53EA-3970-AB50-2296DC7F097F> /usr/lib/system/libremovefile.dylib
0xa7520000 - 0xa7537ff7 libsystem_asl.dylib (356.1.1) <F96973B5-C36B-3037-8AEC-3BF7147D79E2> /usr/lib/system/libsystem_asl.dylib
0xa7538000 - 0xa7538fff libsystem_blocks.dylib (67) <32CE9BB7-E047-3568-981E-4EA94D3DCBB5> /usr/lib/system/libsystem_blocks.dylib
0xa7539000 - 0xa75c5fff libsystem_c.dylib (1244.1.7) <5303B1D1-214D-357C-B08E-AD7500A4133D> /usr/lib/system/libsystem_c.dylib
0xa75c6000 - 0xa75c9fff libsystem_configuration.dylib (963) <A8287AD3-977A-314C-9F75-039A68BD3617> /usr/lib/system/libsystem_configuration.dylib
0xa75ca000 - 0xa75cdfff libsystem_coreservices.dylib (51) <C3D75760-EED5-3C5C-8245-FBD3D9FD60FD> /usr/lib/system/libsystem_coreservices.dylib
0xa75ce000 - 0xa75cffff libsystem_darwin.dylib (1244.1.7) <CDB623E2-9A63-345D-82A0-931EEB5C5B0A> /usr/lib/system/libsystem_darwin.dylib
0xa75d0000 - 0xa75d6ff3 libsystem_dnssd.dylib (878.1.1) <3C00C266-30F6-3DAC-8D54-4504BE6AB9F7> /usr/lib/system/libsystem_dnssd.dylib
0xa75d7000 - 0xa7626ffb libsystem_info.dylib (517) <2EAFB95B-E88C-3D83-8254-4E829D30D95A> /usr/lib/system/libsystem_info.dylib
0xa7627000 - 0xa764aff3 libsystem_kernel.dylib (4570.1.46) <DF6AC242-99E5-3B7B-A4AD-E6A652FD6BC1> /usr/lib/system/libsystem_kernel.dylib
0xa764b000 - 0xa769afdb libsystem_m.dylib (3146) <DBE0AACD-3665-3EEB-BADA-A435E591C54B> /usr/lib/system/libsystem_m.dylib
0xa769b000 - 0xa76b5fff libsystem_malloc.dylib (140.1.1) <DFE0206A-865E-359D-B2F9-FE9DBB3B5B32> /usr/lib/system/libsystem_malloc.dylib
0xa76b6000 - 0xa7752fff libsystem_network.dylib (1229.1.5) <4B88E3E9-7C28-3BBE-8143-5579FE6A71EF> /usr/lib/system/libsystem_network.dylib
0xa7753000 - 0xa775dfff libsystem_networkextension.dylib (767.1.4) <92CBAB05-8D30-3405-92B2-9D92966B2D33> /usr/lib/system/libsystem_networkextension.dylib
0xa775e000 - 0xa7766ff3 libsystem_notify.dylib (172) <63E3CF8C-4F15-3D45-84A6-1218352031E9> /usr/lib/system/libsystem_notify.dylib
0xa7767000 - 0xa776dff3 libsystem_platform.dylib (161) <525A3EF0-E1ED-3EE2-A142-2149A43F9EBC> /usr/lib/system/libsystem_platform.dylib
0xa776e000 - 0xa7778ff7 libsystem_pthread.dylib (301.1.6) <7228A41C-AC5D-3612-B22E-374CB5433D1C> /usr/lib/system/libsystem_pthread.dylib
0xa7779000 - 0xa777cffb libsystem_sandbox.dylib (765.1.8) <79BFD3F5-0BC2-3DA6-A062-79CA966F779A> /usr/lib/system/libsystem_sandbox.dylib
0xa777d000 - 0xa777ffff libsystem_secinit.dylib (30) <CE2C90DE-27A4-3546-8A05-96B743861DD0> /usr/lib/system/libsystem_secinit.dylib
0xa7780000 - 0xa7788ff7 libsystem_symptoms.dylib (820.1.4) <131C3E51-0C07-38A4-9BDA-512D70BFBFD2> /usr/lib/system/libsystem_symptoms.dylib
0xa7789000 - 0xa779bfff libsystem_trace.dylib (829.1.2) <93044936-463B-3E35-9CDF-4B1B83896042> /usr/lib/system/libsystem_trace.dylib
0xa779d000 - 0xa77a3fff libunwind.dylib (35.3) <642BBA03-0411-3FAA-A421-D79A9156AB1C> /usr/lib/system/libunwind.dylib
0xa77a4000 - 0xa77ccff3 libxpc.dylib (1205.1.10) <D1C23A14-2F23-3858-9346-A35B47DFD92F> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2882926
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=283.8M resident=0K(0%) swapped_out_or_unallocated=283.8M(100%)
Writable regions: Total=155.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=155.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 2
Activity Tracing 256K 2
CG backing stores 4020K 4
CG image 1876K 6
CoreAnimation 36K 5
CoreGraphics 8K 2
CoreImage 16K 3
CoreServices 20K 2
CoreUI image file 188K 5
Foundation 4K 2
Kernel Alloc Once 8K 2
MALLOC 135.8M 43
MALLOC guard page 48K 13
Memory Tag 242 12K 2
OpenGL GLSL 128K 3
Stack 12.5M 11
Stack Guard 56.0M 11
VM_ALLOCATE 480K 21
__DATA 13.9M 242
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__IMPORT 4K 2
__LINKEDIT 78.1M 10
__OBJC 3800K 92
__TEXT 205.7M 246
__UNICODE 556K 2
mapped file 262.0M 208
shared memory 872K 15
TOTAL 778.8M 932
Model: MacBookPro13,3, BootROM MBP133.0233.B00, 4 processors, Intel Core i7, 2.7 GHz, 16 GB, SMC 2.38f7
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 455, AMD Radeon Pro 455, PCIe, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.37.0.1a1)
Bluetooth: Version 6.0.0f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.2
DJP13
Re: Showxpress crashes every time I open
Postby support » 03 November 2017, 12:06
Please send a zip of the folder "TheLightingController" which is stored in the "home directory" of your system.
https://thelightingcontroller.com/viewt ... p?f=3&t=19
Postby DJP13 » 06 November 2017, 14:21
sent
DJP13
Postby support » 06 November 2017, 18:22
We did not receive it.
Please double-check.
Postby support » 07 November 2017, 08:50
You sent your software folder, while we need your lightshow.
Please send your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168).
Postby MGa » 08 November 2017, 08:10
Any updates if High Sierra is working without an issues? Would love to use the new upgrade but I need to still be able to do shows. If not, any timeframe on when it will be good to go?
MGa
Postby support » 08 November 2017, 11:58
Your lightshow opens fine with our system (see attached picture).
Please note that we use only the latest version of our software 8.2.24 (August), while your lightshow says that the version of your software is 8.2.18 (March). So please try with the latest version of our software.
BTW, could you please also send us the file "param.ini" in the folder "YourHomeDirectory/TheLightingController/" ?
Postby DJP13 » 08 November 2017, 16:46
I have updated to the latest version of your software (8.2.24) and showxpress still is not opening.
My main computer updated to macOS High Sierra Version 10.13 and showxpress crashes every time I try and open it. However, my bosses computer is running the previous version of macOS and his showxpress opens fine. I believe there is a bug within High Sierra version 10.13 that is causing the crashes.
Any advice on how to get this resolved ASAP would be appreciated, I need this software functional for upcoming jobs this week.
Thanks.
DJP13
Postby DJP13 » 08 November 2017, 16:51
The file you requested has been sent
DJP13
Postby support » 08 November 2017, 17:51
No problem here with your lightshow and your file "param.ini", under our "High Sierra" system.
Could you please try without any usb device (neither our dmx interface, nor any other usb device) connected to your computer ?
Next
Return to Mac OS
Users browsing this forum: No registered users and 10 guests
