Auto BPM
Auto BPM
Postby djlivewire » 19 October 2017, 19:06
Hi everyone
i have seen this posted a few times but most of the conversations are quite old , i use macosx and can't use auto bpm only manual, i know this works on windows
is there a new version with this or can is there a midi controller not too expensive that i can plug in audio ,
as a dj i just want some things (colour or shutter) to change to the beat , pressing the drum can't be done while mixing
any help is appreciated
djlivewire
Re: Auto BPM
Postby support » 20 October 2017, 09:06
We understand the difficulty to press the "drum" button while mixing, but unfortunately the real time bpm analyse is not accurate enough.
So far, all lighting software have the same problem, and all work around it with the "drum" button.
Please note also that there is a new beta (no GUI menu but working) "midi clock to BPM" function. Please read this: https://thelightingcontroller.com/viewt ... =76&t=4260 .
Re: Auto BPM
Postby djlivewire » 24 October 2017, 12:17
Thank you support , do i need any hardware to connect the audio output of the mixer to the laptop running the lighting program
Many thanks
djlivewire
Re: Auto BPM
Postby support » 25 October 2017, 08:52
We do not understand this question.
So far, it has nothing to do with the "midi clock to bpm" feature, and our software does not manage sound under MacOS.
Re: Auto BPM
Postby SeekLighting » 25 October 2017, 10:35
Hey DJ livewire, as support is saying, Midi clock has nothing to do with audio. Midi clock takes the tempo information from MIDI signal and sends it to the BPM in showxpress. So let's say you are using your DJ program and the tempo is set to 128 BPM. Connect a MIDI cable from your dj system to your showxpress Mac (or use internal midi routing), then follow the instructions to code in the midi clock send that Support linked in his post :). This will then set your BPM in Showxpress to 128bpm, and the tempo in showxpress will change automatically to whatever tempo your DJ session stuff is set to (you'll have to forgive me I'm not a DJ so I'm not sure how that stuff works)
As Support said, this has nothing to do with audio, just MIDI signal :). It will accomplish what you are effectively trying to get the auto BPM to do
SeekLighting
Re: Auto BPM
Postby djlivewire » 03 November 2017, 20:27
Hi guys , still trying to get a fix around this , i have connected my DDJ-SZ to my lighting mac set the midi in cahnnel to 1 , in showxpress under the live settings tab i have set the BPM/drum in to device 1 channel all , why does this not work ?
Im new to midi so sorry for not understanding straight away
My setup is two macbook pro , one running serato dj with a pioneer ddj sz , the other mac is running showxpress
Thanks to everyone trying to help me out
djlivewire
Re: Auto BPM
Postby rvanscoyk » 23 November 2022, 21:10
Has this problem been solved in the last few years? I would love to use Auto BPM on a mac if it's an option. I play audio from Spotify, and can use BlackHole to route the audio into ShowXpress if there's a way to do so. For my pre-planned light shows I use MIDI commands from Logic, but I like to have other songs run some sound active programs and don't want to have to tap in the tempo each time the song changes.
rvanscoyk
Re: Auto BPM
Postby support » 23 November 2022, 21:34
Solved for the next major version of our software.
Return to Mac OS
Users browsing this forum: No registered users and 7 guests
