Auto bpm
Auto bpm
Postby Matthoffman58 » 29 June 2017, 22:08
I believe the auto bpm was removed from the SX mac version as it was deemed "not as accurate". However this feature is required to use with the virtual dj plug in. I was not aware of this when deciding to go with SX. Is there a valid reason for removing it as I don't see how you can get more accurate then getting the bpm directly from VDJ?
Was this removed in preparation for a partnership with serato and the soundswitch? Is there any workaround for getting a bpm into SX now?
Matthoffman58
Re: Auto bpm
Postby support » 30 June 2017, 07:17
The "auto bpm" is to analyse the music played by the computer, in order to try to sort its bpm.
It has nothing to do with Virtual DJ.
Re: Auto bpm
Postby Matthoffman58 » 01 July 2017, 01:11
Fair enough, but when I use the virtual dj plug on a pc it sends the bpm to SX and works flawlessly when I engage auto bpm. Is there another way to bring the bpm into SX from an outside source?
Matthoffman58
Re: Auto bpm
Postby support » 01 July 2017, 09:29
No there is no other way.
FYI, the "manual BPM" is another solution. Just tap the space bar a few times, and the bpm in our software will be ok for the whole song.
Re: Auto bpm
Postby Matthoffman58 » 01 July 2017, 13:53
Why was the auto bpm removed from the mac version only? And why would it be removed at all? Doesn't make sense why useable functionality, and one that automates a process was removed at all.....
Matthoffman58
Re: Auto bpm
Postby Matthoffman58 » 07 July 2017, 17:57
Any updates in why auto bpm was removed?
Matthoffman58
Re: Auto bpm
Postby support » 08 July 2017, 14:04
Where did you see that this feature has been removed ?
Re: Auto bpm
Postby Matthoffman58 » 09 July 2017, 21:29
Maybe not removed, never added is more accurate. Unless I'm just missing something....
Seems odd not to implement because "our experience says users prefer to use manual BPM, for higher accuracy." Why include it with the pc version then?
Matthoffman58
Re: Auto bpm
Postby support » 11 July 2017, 11:27
We tried the "real time BPM analyse" under Windows (the "sound card" code is completly different than for MacOS), but the result is not accurate enough.
So we stopped working on this.
Re: Auto bpm
Postby Matthoffman58 » 12 July 2017, 02:49
Appreciate the additional color.
In the case where I am importing a beat grid (bpm) into SX, the accuracy of an internal mic is not relevant. Is there anyway you can incorporate a "import bpm from external source" feature?
Id be happy to help facilitate a discussion between SX and virtual dj if you needed any technical info in the import...
Matthoffman58
Next
Return to Mac OS
Users browsing this forum: No registered users and 10 guests
