Control board crashes [fixed]
Postby Simon » 05 October 2010, 12:14
I've had the control board crash several times when opening up and I've now lost the green flashing 'PC link' light. I can provide the most recent crash report if that would help. Is there a way to restore the box's settings and regain the connection?
Simon
Simon
Re: Control board crashes
Postby support » 05 October 2010, 13:01
What is your software version, and what is your interface ?
Postby Simon » 05 October 2010, 14:25
Software V 6.24 for Mac and and I'm using it with Sweetlight Remote unit. I have started another thread under the Sweetlight Remote section as I'm not sure whether its the unit or the software.
Simon
Simon
Postby neonnightz » 02 November 2010, 07:15
I have had the same problem but with the ssa interface and im runnig 6.25 sweet light software
neonnightz
Postby Simon » 02 November 2010, 09:21
I tried everything suggested to me without success and eventually returned the unit to my supplier, suspecting a fault with the hardware. The replacement arrived a couple of days ago and I haven't had a chance to test it yet! Fingers crossed.
Simon
Simon
Postby support » 02 November 2010, 17:40
Simon, so you just double click on ControlBoard to open it , and it crashes ?
If yes, please make the test with and without the interface connected to your Mac, and let us know when it crashes.
Re: Control board crashes [moved]
Postby Simon » 03 November 2010, 09:28
I now have a new Sweetlight Remote and its working fine with no crashes. I can only assume it was a hardware issue that has been solved with the replacement unit.
Simon
Simon
Postby support » 03 November 2010, 09:57
Thank you for your answer.
We look forward to have your interface in our hands to check it.
Could you please send us a copy of your lightshow (viewtopic.php?f=3&t=168) ?
This might help us, in case of you discovered a bug which crashes the firmware of the interface, after scenes uploading procedure.
Return to Mac OS
